Have been trying to find axle load limits for LC 100 petrol V8.
Has Pedders upgrade and 2" lift kit.
No info in manual (Says not to modify Toyo suspension)
Fully loaded front= 1.38
rear= 1.68
I am fairly certain that rear is overloaded.
On the van we have removed 1 spare wheel and hoping to put genny in a box on the back (Spare wheel -30kg, Genny and box +40kg)
Will put up the van specs once I get the axle loads sorted.
-- Edited by Snippy on Saturday 6th of March 2021 04:54:38 PM
yobarr said
06:07 PM Mar 6, 2021
rear= 1.68
Hi Kevin....do not panic! Front axle is (factory specs before upgrade) 1630kg and rear axle is rated at 1950kg.Load-em-up,if you wish,as GVM is 3260kg! You've got 200kg to spare,and,with careful loading,you can actually reach the 3260kg figure because of the fact that the two axles have a capacity that is 320kg more than your GVM.Cheers
-- Edited by yobarr on Saturday 6th of March 2021 06:20:34 PM
Snippy said
02:48 PM Mar 7, 2021
Thanks Yobar, now to do the van re-arrangement. Watch this space.
yobarr said
03:27 PM Mar 7, 2021
Always happy to help,Kevin,despite sometimes getting contradicted by a couple of members who know little,understand less,and have no apparent interest in expanding their own knowledge base...C'est la vie! Cheers
rear= 1.68
