I want to clean underneath and install USB cable to run for devices in back.
TheHeaths said
04:18 PM Nov 2, 2020
I dont know how you would do this, but suggest posting in the technical section as few people visit here, and there are a number of members with D Max who may be able to guide you.
Greg 1 said
07:38 PM Nov 2, 2020
Aside from cleaning, running the cable should not be an issue. Use a piece of stiff wire and pass this from the rear up under the console and out at the front. You may need to do this to one side to dodge the gear change mechanism etc. Once that is done, tie the cable onto the draw wire and pull back through.
dickyknee said
05:59 AM Nov 3, 2020
Okay and thank you
dorian said
06:16 AM Nov 3, 2020
From the forum rules ...
"The forum is divided into a number of sections to allow members and visitors to more easily find the discussions that are of interest to them. We ask that members try to post in the most appropriate section for their subject matter in order to facilitate the smooth running and efficiency of the forum."
Can anyone give detailed advice?
Okay and thank you
Am I in the correct forum now, I am a newbie
