After 3 days parked up the fridge stopped working and defrosted. when we got home plugged in the power fridge worked fine. Is this usual.
rgren2 said
10:27 PM Mar 16, 2020
Really might help if you told us what fridge you have.
08:21 AM Mar 21, 2020
Very thin on data to go on!
how many times did you open the fridge while away & at home?
How humid was it while away & at home?
07:03 PM Mar 21, 2020
How low was the voltage ? 3 way or compressor ?
Tony Bev said
02:25 PM Mar 22, 2020
Hi patmc49
To answer your question, on all the caravan type fridges I have had, it was not normal for the fridge to stop, unless something was wrong with it
As others have already said, if you give the name, type, and model, of your fridge, the techies may be able to help
erad said
09:27 PM Mar 22, 2020
By the sounds of the original poster, the fridge was operating on 12V (beit auto or manual setting) as they were travelling. When they stopped suddenly the 12 V supply disappeared. Maybe there is an isolator in the car's power supply for the van? It is most likely a 3 way fridge because it runs on 240 V (if it was a 12 V compressor fridge, it probably won't go on 240 V either). Connect it to 240 V and it goes. A few days later and the tug's battery is still not flat, so I reckon it is the 12 V supply in the tug or the 12 V element blown in the fridge.
Hi patmc49
