Having difficulties lifting my poptop on 2014 Jurgens Wallaroo. Anyone have experience with newer lift bars or the air jack systems..? or any other advice for a DIY solution preferably.
-- Edited by Mindi on Tuesday 16th of July 2019 01:31:12 PM
Colin Penrose said
02:07 PM Jul 16, 2019
Hi. When I put a 200w solar panel on the roof of my pop top I found it much harder to lift up. My solution was to replace the gas struts to a heavier Nm rating. Cheap fix in the long run. Col
Olive Oil said
03:30 PM Jul 16, 2019
Are you keeping the door open while you lift it?
If the door & windows are shut it creates a vacuum which makes it twice as hard to lift the roof.
Mindi said
06:54 PM Jul 16, 2019
thanks Col..could be the answer
Sheba said
06:58 PM Jul 16, 2019
Check out RV Airlifters.
dieseltojo said
07:23 PM Jul 17, 2019
Hi Mindi, I stand on the step and unroll the awning a few turns prior to the lift. I have 6 panel on the thing and manage no worries. I am 73.
But I have no health problems. I have read good things regarding the air bag support system but not sure on its longevity.
Mindi said
09:06 AM Jul 18, 2019
Thanks to all for your help. Problem solved. The Jurgens Youtube clip called "Jurgens Poptop" shows their new Easy Up/Easy Down mechanism which they will supply as a kit for about $250 or fit for you for an additional $160. That's my preferred way forward.
https://www.youtube.com/watch?v=7LPzIKubNNE
