Hi Has anybody had problems with there dometic harrier aircon leaking, ours is leaking only when driving/moving when its raining , when camped up not moving it doesn't leak even in heavy rain. any help appreciated thanks. Ray
Gundog said
01:36 PM Jun 2, 2019
We have a Harrier and have not encounter any problems with leakage.
If you download the installation instructions from domestic it will show you how to access the mounting bolts to confirm they are tight, outside of that then there maybe insufficient sealer or missed bit when installed.
There is a difference in how the mk1 and mk2 Harrier is installed.
How to identify a mk1 harrier it has a row of led lights on each side near the display, where the mk2 has diffusers covering the led's
Marlene6 said
04:34 PM May 6, 2021
Harrier lite in avida birdsville leaking everything we have rain.
Back to dealer 3 times. No solution to date!!
