Can anyone recommend the Aussie caravan covers or let me know what they are like.
Thank you
Mike Harding said
10:08 AM Oct 15, 2018
I have two friends with caravans with covers. Both say it is a multi person job to put the cover on the van and a major pain in the bottom to boot. Both also say they very rarely use the covers nowadays.
Possum3 said
10:21 AM Oct 15, 2018
Covers, even the good expensive ones only last a couple of years in the weather - great as dust covers in a shed. The cost of a simple carport should be considered you can have a section of roof with alsynite to allow solar panel/s to keep tickling up your batteries. You can run a 15amp power outlet to a structure, café blinds can be added for total enclosure. No half day effort to use a cover. Security devices are better when links can be set in concrete floor for attachment to chains. Best of all it doesn't need to be bought again every two / three years.
elliemike said
11:32 AM Oct 15, 2018
Having had two Camec covers over the past years and found that they were OK for a while, then deteriorated in the sunlight I suppose. Becoming powdery on the outside and letting water in. I now use a Grey Tarp from Bunnings.
They are the cheaper and last longer. So far after three years very pleased with the "Grey" tarp. (Don't bother with the blue ones)
Cupie said
10:55 PM Oct 15, 2018
I too use the grey/silver tarps with shade cloth over it. I get the best available.
Get about 5 years out of them.
The disadvantage is the extra time to fit.
Should have built a 'garage'/roof 20 years ago. Soo much easier & better.
Thank you
