Seeking some information please. We have travelled today for about 4 hours - say 200ks. Stopped at Coonalpyn in SA checked the tyres on the van and found one of the back tyres and hub were very hot, the other three are fine. Any advice as to what could be causing this? After stopping for 30 mins the tyre and hub have cooled. We will stop in Coonalpyn tonight.
Time now 2.00pm
Thanks Terry
Aussie1 said
03:12 PM Jul 2, 2018
I am not a mechanic but it sounds like a bearing is worn or breaking down. Suggest you have checked asap and preferably before you leave the place you are at. Good luck and stay safe.
Dave1952 said
03:38 PM Jul 2, 2018
I agree with Aussie1. That is a classic symptom of a collapsing bearing. After losing a wheel on a previous van in 2006, I always carry spare bearings and HTB grease as well as rags and the tools to replace a bearing if need be.
erad said
03:44 PM Jul 2, 2018
You could have a brake on the van sticking on as well - this would cause the tyre to run not. More likely the wheel bearing. Jack the wheel and see how freely is spins - if it drags, it is probably the brake. If it spins freely, brake is in the clear,. Check then for free play in the bearing - shake the wheel in the vertical and horizontal axes and see if there is excessive movement If there is, try to adjust the wheel bearing, but you are probably up for new bearings.
Possum3 said
05:18 PM Jul 2, 2018
Also consider that it may be running on too low pressure - that will heat up a tyre/wheel.
outlaw40 said
06:43 PM Jul 2, 2018
all good suggestions but i think if you need to come onto a forum looking for advise on a matter like this you to seek out a mechanic to solve your problem .
07:01 PM Jul 2, 2018
(1)Dry bearing ( no or little grease ) or too tight . They fail Very quick tho . (2) Dragging brakes . (3) Or tyre pressure too low ??
2558 said
08:08 PM Jul 2, 2018
Thank you everybody I really appreciate your feedback / suggestions. We will of course get a mechanic to see the caravan tomorrow but at least i now know what may be wrong and if it happens again I know what to look for. A great forum.....thanks again. Terry
vince56 said
08:15 AM Jul 7, 2018
Hi 2558, It would be good to get some feedback on what the fault ended up being?
Hello
Time now 2.00pm
Thanks Terry
