have installed a 5kw PPAP diesel heater worked fine for a couple of days then wouldn't ignite.can hear and see fuel pumping to heater exhaust gets warm then starts to blow heaps of white smoke, fan is running then E-08 code and unit shuts down.
The book says the E-08 code is "Combustion termination over times and stops"
The ebay seller has been great sent me a new fuel pump not luck ,sent a new esu unit still no luck just wondering if anyone has had a similar problem that maybe an easy fix.
Joda said
09:21 AM Jun 13, 2018
Looked in techies, revemike had the same problem, some good info in that post,
Joda
Felance said
09:59 AM Jun 13, 2018
Thanks for the info Joda had a look and it has given me some good info to try... thanks again
10:07 AM Jun 13, 2018
Ahh! There 'tis. the problem I missed in the other thread
Good advise checking Techies.
Hope that you get it all sorted
