I have just finished installing a PPAP Diesel heater and Im having some issues. It seams the ECU is the main cause and the seller is sending a new one.
My question is about the operation of the fuel pump.
When I primed the system and applied power direct to the fuel pump it clicked once then stopped. By continuing this process, apply then disconect then apply, I have been able to prime the system.
From my experience I expected that when I energised the pump it would run continuosly till it reached pressure.
Is this a correct assumption or does the ECU drive the pump by energising then disconnecting?
Dickodownunder said
02:06 PM May 17, 2018
Hi Bruce,
You may get more of a response posting in the Techies forum.
I fitted a diesel heater in my previous van and I primed the system by gravity and then after a couple of on and offs it operated just fine.
There appears to be more and more problems now with these cheaper heaters than there was when I bought and fitted mine.
Mind you I thought my kit was cheap at around $700.00 (complete) compared to what some of them where costing back then.
Bruce Mc said
06:27 PM May 17, 2018
Thank Geoff
I thought I had posted in Techies Corner till I saw your post.
Have now listed it there also.
Thanks again.
jkis said
07:06 PM May 17, 2018
Hope this will help someone
https://www.letonkinoisvarnish.co.uk/eberspacher_fuel_2.html
KJB said
07:40 PM May 17, 2018
Excellent article........ simple and clear.
Bruce Mc said
10:52 PM May 17, 2018
Thanks heaps, the article answers my question.
The ECU pulses power to the pump, switching power on and off to provide a single pump of fuel.
I can relax now.
RoamerAllWaze said
01:53 PM Dec 30, 2018
jkis wrote:
Hope this will help someone https://www.letonkinoisvarnish.co.uk/eberspacher_fuel_2.html
Thanks for that link VERY helpful in understanding pumps.
Thanks again.
I can relax now.
