would like to renovate our van with new flooring, either self adhesive vinyl tiles or floating timber look flooring, any ideas?
the rocket said
06:22 PM Feb 6, 2018
Hello matilda, let me be the first to welcome you. Floorings a tough one. We bought wall runner from bunnings. Cut to the length u want. If we redid the floor i expect i would try vinyl self adhesive tiles. Join in n enjoy. Regards rocket n strop
SouthernComfort said
08:04 AM Feb 7, 2018
I'd stick with what the manufacturers use - fitted vinyl floor covering. It gives a better seal against spillages and as it flexes it's more resistant to lifting as the van travels.
-- Edited by SouthernComfort on Wednesday 7th of February 2018 08:06:08 AM
-- Edited by SouthernComfort on Wednesday 7th of February 2018 08:07:15 AM
Bagmaker said
08:10 AM Feb 7, 2018
Hi Matilda,
we have used some KARNDEAN product on our walls and would also recommend it for flooring -its intended use-, comes up really nice
matilda said
08:51 AM Feb 7, 2018
Thank you for the help
madaboutled said
10:25 AM Feb 7, 2018
We went down the self adhesive path putting in Wood Grain style vinyl planks (750mm long x 125mm wide). Easy to do, cut and trim, finished job looked fantastic. Then a couple of hot days and the planks contracted width wise creating a gap between them. I thought it still looked "OK" til a friend made the comment "why the large gap". So, might be time to rethink the flooring again.
10:43 AM Feb 7, 2018
Soma by new floor covering out there these days . One thing to be aware of . We replaced more of our carpet with vinyl . To our surprise the original vinyl covering went under the carpet . But we found it very slippery till we fitted some mats . The larger area made it more prone . Much much easier to Broom out floor now !
