I just purchased a 2nd hand Landcruiser which has an exhisting 350Amp Anderson plug. Can somebody tell me what this would be used for? I'm thinking of removing it if I don't have any need for it.
many thanks
dirvine said
03:40 PM Aug 31, 2017
Maybe for a winch? That is a very high current plug, and about the only thing that draws heaps of current is an electric winch. Where is the plug located?
Hostie said
05:50 PM Aug 31, 2017
It's near the towbar on the back.
hako said
06:38 PM Aug 31, 2017
Probably just something the previous owner had lying around in their shed and figured it will do. My father in law was an electrician and for the trailer plug on his box trailer he used a 3 pin electrical plug - park,stop and earth. This was before blinkers were common.
Good Luck.
diggerop said
07:38 PM Aug 31, 2017
I've seen some pretty heavy plugs on fitters vehicles for jump starting equipment with 24v systems. There'd be a couple of big batteries in the back wired up as the 24v supply. There'd be a matching plug on the equipment.
Desert Dweller said
07:42 PM Aug 31, 2017
Probably a left over from a bored DIY retirees meddling. Get rid of it & visit an Auto Electrician to trace the wiring for your peace of mind.
aussie_paul said
07:47 PM Aug 31, 2017
No fun in that DD
08:29 PM Aug 31, 2017
It would be a 50 amp grey Anderson plug to supply power to a campertrailer or caravan to charge it's batteries.
rgren2 said
08:24 AM Sep 1, 2017
They are often put on mining vehicles. Used to jumpstart others Or power lighting.
keiron said
10:16 AM Sep 1, 2017
Often used on Roas Service (NRMA) type vehicles, for jump-starting etc.
Dr Ric said
01:49 PM Sep 1, 2017
Most likely used for a boat winch.
madaboutled said
03:24 PM Sep 1, 2017
I'm more curious in what size cable is in the plug?
Hostie said
03:52 PM Sep 1, 2017
6mm cable
madaboutled said
06:59 PM Sep 1, 2017
Hmm, have to agree with what hako said earlier... was probably something left lying around that would do the job... or words to that effect.
07:34 PM Sep 1, 2017
6mm won't even get there over the distance !! Maybe run a fridge ? 8 amp max over distance., Dreaded VD !!
Peter_n_Margaret said
09:25 PM Sep 1, 2017
I have 400A Anderson plugs front and rear of the OKA for a movable winch.
But it also has 50mm2 cables to it.
gday,
many thanks
Good Luck.
No fun in that DD
6mm cable
