It's usually in the way it's mounted .. Or the pipes off it are vibrating against body etc ? Should be mounted on strong ply that prevents harmonics . Or rubber mounts between pump and mounting .
Cadpete said
09:04 PM Jul 25, 2017
G'day Manta Ray and welcome to the forum. Don't forget to try the two ongoing games here - 'Who is This' in the 'I Digress' section and 'Pick this Place' in the 'General' Section - a great source to find new places to visit. Reckon Aus-Kiwi covered the main points re pump noise.
09:11 AM Jul 26, 2017
Welcome to the gang Manta Ray, enjoy here and out in the playground.
Caravans often have various noises in them so I tend to just put up with them. My pump is not over noisy so not too bad there. I have a continuos Flow hot water service that IS noisy though but getting rid of it soon for a Suburban HHS.
Keep Safe on the roads and out there
iana said
10:09 AM Jul 26, 2017
The water pump in our van is noisy, I have looked at the installation and it seems OK, while I have yet to investigate fully, it could be just the design of the pump. may I suggest you put the question up again in the technical section.
09:59 AM Jul 29, 2017
Yes may be fitted ok . If it's atttached to floor or structure that can vibrate the harmonics of pump are exaggerated like a big sound shell .. Often fitting a 7 ply sikoflexed to floor another rubber strip between pump and 7 ply with screws holding pump . It MAY need an acumuator if pump is turning on and off too often ?? With out one it could be hammering your pipes ? Much the same at home when when tap is turned off quick ., Saddle pipes .
the rocket said
08:28 PM Aug 3, 2017
Hello manta ray, sorry cannot help with your question but wanted to say hello and welcome. Enjoy.
how do you reduce water pump noise
just had new water pump fitted and a split system
fitted water pump noisy
thanks dave
