We just purchased a 2010 XK559 caravan it had no Geist manual so I am needing some good advice :-
1. What is the best tyre pressure for a single bogey van with the maximum 250 kg payload ?
2. Can I use a 18 Volt cordless drill to lower the legs and if so, can I cut the Geist crank handle to create a straight shaft ?
Any good feedback on these matters would be appreciated
Regards Nobby
Possum3 said
04:41 PM Jul 22, 2017
Maximum tyre pressure will by stamped on side of tyre - normally would suggest 35-49 PSIG on light truck tyres - do NOT cut crank handle buy a socket extender - if battery on drill gets flat you won't be able to use stabilisers.
John Kay said
04:58 AM Jul 23, 2017
Nobby Simpson wrote:
Calling all Geist owners,
Regards Nobby
FYI. Single refers to one axle with two tyres. Bogey refers to two axles with four tyres.
Regards John K
TheHeaths said
08:44 AM Jul 23, 2017
Nobby,
to give some guidance it would help if you could provide the weight of the van loaded (at least the ATM from the compliance plate), and the maximum load at what pressure as stamped on the side of the tyres.
From that it is possible to work out a decent starting pressure by using the formula, ATM divided by the sum total of the tyre maximum weight (if 800 kg is maximum stamped on tyres then this would be 1600). That gives a ratio. Then multiply the Maximum pressure as shown on the tyre by that ratio and that gives a starting pressure to use.
As An example. ATM on plate 1500 kg, Maximum tyre weight 900 kg each, maximum pressure allowable 50 psi at the 900 kg.
Formula would be 1500/1800 (twice tyre maximum) which equals 0.83. Multiple 50 PSI (Maximum tyre pressure) by 0.83 gives a starting pressure to use of 41.66 PSI.
Put your figures into that formula and see what it comes to.
To get a more accurate figure, use an actual weighed weight of the van rather than the ATM off of the compliance plate.
-- Edited by TheHeaths on Sunday 23rd of July 2017 08:50:23 AM
01:19 PM Jul 23, 2017
Ian has given a good guide to a pressure to start with. Pump your tyres to that pressure. Then on your first trip measure the pressure at your morning tea stop. It should be around 3 - 5 psi higher than the cold pressure. If it is higher then you need some more wind in the tyres. If the rise is lower then there is to much wind in the tyres. Adjust the pressure when the tyres are cold again and then do the temp/pressure test again on the next leg of your trip.
Desert Dweller said
02:12 PM Jul 23, 2017
I'd recommend running your caravan over a weighbridge to check exactly what payload you have. Just because it's written on the compliance plate doesn't made it gospel.
Brother-in law & sister could only put their socks & undies in their Geist before being overweight.
I'd be keeping you tyre pressures as low a possible to soften the ride. As I said on another of your threads our relatives caravan never went off the bitumen but cost thousands to fix lots of cracks in the sub-frame before the A-frame snapped & it ended up in a roadside drain. Parts are like hens teeth.
Hopefully that doesn't happen to you. Happy, safe travels.
-- Edited by Desert Dweller on Sunday 23rd of July 2017 02:13:10 PM
Nobby Simpson said
03:31 PM Jul 23, 2017
Thanks Possum 3, I appreciate your advice
Regards Nobby
Nobby Simpson said
03:32 PM Jul 23, 2017
Thanks Ian. Much appreciated
Nobby
Nobby Simpson said
03:34 PM Jul 23, 2017
Useful info Peter D. Many Thanks
Nobby
Nobby Simpson said
03:35 PM Jul 23, 2017
Thanks John K, I sit corrected
Nobby
Nobby Simpson said
03:38 PM Jul 23, 2017
Thanks Desert Dweller,
I'm off to find a gun BOO HOO !!!
Nobby
Landfall said
07:00 PM Jul 23, 2017
We used to run our Geist tyre pressures at 45psi cold.
I got a spare handle style leg socket and cut it as you have indicated, but as stated if your drill goes flat you are in trouble.
A better option that I eventually went with was a long 1/2" extension bar and deep wall socket on an 18volt Ryobi impact gun, this also gave me the option of undoing the wheel nuts should I have a puncture.
Also check the age of your spare tyre, a lot of them would now be ten years old.
Regards Nobby
Regards John K
Nobby,
Regards Nobby
Nobby
Nobby
Nobby
Nobby
Thanks Landfall,
I will check that out.
Nobby
