Hi, we are looking for a bench mount for our tv in our caravan, so far we have found wall mounts only!!
Yuglamron said
03:01 PM Jul 15, 2017
Hi,
I would be looking at places like Office Works for desk monitor arms and see if they have something suitable for your needs.
Desert Dweller said
03:58 PM Jul 15, 2017
Don't all TV's usually come with a bench mount? Obviously not?
Bushbaby said
04:30 PM Jul 15, 2017
Some tv's do come with bases, this one has legs! Also need the base to swivel!
Bushbaby said
06:00 PM Jul 15, 2017
CC Bear said
06:31 PM Jul 15, 2017
When you find one can you report back with a link, price and who from, thank you
-- Edited by CC Bear on Saturday 15th of July 2017 06:32:25 PM
Bushbaby said
06:38 PM Jul 15, 2017
Ok will do!
Cupie said
11:12 PM Jul 15, 2017
I just made one myself. About 15 years ago.
Used a piece of material that had been cut out from the kitchen bench to fit the sink.
Cut it into a circle with a hole in the centre.
Fixed that to the bench where the TV sits. Just used a cup head bolt with a wing nut secured from below.
A bit of dense foam between the base & bench to act as a damper.
Made up a couple of brackets to hold the TV base to the swiveling base. You could even screw through the TV stand into the base plate.
Never moved for 200,000KM.
edit .. To fix my electric fan to another bench, to avoid drilling through the bench I just screwed it to a bit of heavy gauge tin plate (cut from an old computer case I think) that was made to fit with a couple of tags jammed between the wall & the bench top and a couple of L shaped ones at the front that allowed screwing up from under the bench top. That approach doesn't allow the whole fan (or TV) to swivel though. A small mod could overcome that ... perhaps a second base plate swiveling on the top ... a bit iffy though.
OK for my old van but perhaps not nice enough for a modern one.
-- Edited by Cupie on Saturday 15th of July 2017 11:21:09 PM
-- Edited by Cupie on Saturday 15th of July 2017 11:23:04 PM
Eaglemax said
11:49 PM Jul 15, 2017
This ceiling one can be used on a bench by the looks if it
http://www.cablechick.com.au/cables/fold-away-lcd-tv-ceiling-mount-20kg-black.html
John Kay said
03:02 PM Jul 17, 2017
We purchased a 24 inch (12 volt ) Teak TV with a stand already attached. They are available. Cheers John K
Tony Bev said
10:55 PM Jul 19, 2017
If you are looking for the type as the picture below
Hi,
Below is a link to one at Office Works $88
https://www.officeworks.com.au/shop/officeworks/p/brateck-lcd-monitor-table-stand-with-arm-and-desk-clamp-black-anbtlcdt6b
Below is a link to an Australian seller on EBay $45
http://www.ebay.com.au/itm/Single-HD-LED-Desk-Mount-Monitor-Arm-Stand-Display-Bracket-Holder-LCD-Screen-TV-/391801417701?epid=930767292&hash=item5b392f2fe5:g:FSQAAOSwrfVZVxJh
Hope that the info is useful to you
-- Edited by Tony Bev on Wednesday 19th of July 2017 10:57:07 PM
