Clear view mirrors on a Ford Ranger wind wilseling noice roduct
Col Rennie said
11:10 AM Jun 3, 2017
Advise or ideas please.
I have a 2016 Ford Ranger with Clearview mirrors fitted for towing .I have a wind wilsiling noice on the driver side as soon as I get up to 80k.
When I pull the Mirror in flat to the truck it goes away.
Ford tell me it's the mirrors not the Truck and the fact that the noise goes away if I pull the mirror in dose point to that as the issue.
I really don't want to stop using the Clearview product .
Any ideas ?
That you
I have anew Ford ranger
11:35 AM Jun 3, 2017
I have Clearview on my Collie and no problem at all. I think Ford will tell you anything because it is not their product. Have a chat to Clearview. I find them great to deal with.
I had a problem where the R/H indictaor on the Clearview stopped working so took the car to them as I could at the time and they found a short on the car side of the connector. No charge. Took the car back to Holden and they said not their mirror and would charge. NO, NO WAY said I, it is on the car side of things and nothing to do with Clearview. Stood my ground. They sorted the problem Free of charge and were not happy campers at all. Too bad.
I only just recently had what I thought was a noise up front and turned out to be tyres so had them rotated and a front end alignment and much betterer.
I know what you are saying about folding in the mirror etc but it could be something else, just a thought.
Dickodownunder said
03:10 PM Jun 3, 2017
Hi Col
You could get some child's play dough and use small pieces to try to isolate where the whistle is coming from.
Try placing pieces of it on all the gaps in the vicinity of the mirror and the area where it mounts on.
If the whistle stops when it is placed in a particular area you then may do what Doug did and insist the dealer fix the problem if it has nothing to do with the Clearview Mirror.
Dickodownunder said
03:15 PM Jun 3, 2017
Another thought is that my Clearviews have a rubber gasket between the surfaces where the mirror mounts to the vehicle .
Just check that the gasket is in place.
I know when I fitted mine I had trouble getting the gasket into the correct position.
Maybe even the installer neglected to fit it.
Cruising Cruze said
08:50 PM Jun 6, 2017
Ho Col
I was thinking,If you don't have the problem mentioned above
why not try to close the gap between the 2 bars of the mirror with some 100 mile tape to see if it is still there ?
Just an tough I can be completely wrong
Regards John
kezngaz said
10:33 AM Jun 12, 2017
Try refitting the original mirror, if the noise goes then you have found your problem.
Hope this helps.
Kezngaz.
Any ideas ?
That you
Regards John
Hope this helps.
Kezngaz.
