Am I being ripped off with exchange bottles of L.P.G. ???
kiwijims said
11:01 PM May 30, 2017
When I place a full 9kg bottle of gas on my B.B.Q. I know that it's good for at least 5 barbies
Last Saturday we were having the usual "Barb & Bitter" when the burners gave a cough and died,
That's funny I thought, maybe a block in the line, when I went to remove the bottle, I found it completely empty, and that was only the third time I had used the B.B.Q since I fitted a full bottle. which I had exchanged at Bunnings. ?????
From now on I will be getting my refills from B.B.Q's Galore, the price is exactly as Bunnings ... $19.95 x 9kg , but at B.B.Q's Galore, you see the bottle being filled and know it's full, I know that they only fill in-date bottles but that's not a problem as my bottles have years of life left in them.
To my way of thinking, we pay enough for gas now, with-out being short changed into the deal !!!
K.J.
12:18 AM May 31, 2017
Often short filled ?
Lancelot Link said
01:03 AM May 31, 2017
Refills here in Victoria at those replacement bottle places are now no longer 9kg. Even though the bottles are rated at 9kg, they are not allowed to be filled to the 9kg amount. Explained to me by an irate service person who was annoyed at having to explain it to people! Maximum allowed is 8.5kg! Don't abuse or shoot me down, only relaying that company policy has changed. Sort of like cereal packets getting smaller and charging the same! Yet, the same bottles, refilled at a refilling centre are guaranteed 9kg, if you watch the person doing it and doesn't screw the screw in before the solid stream of gas comes out.
06:39 AM May 31, 2017
Not abusing you, just putting you straight - straight from the horses mouth. Scroll down to the heading "Why 8.5kg and 3.7kg Refills?"
KevinC said
07:44 AM May 31, 2017
Very interesting Peter. That means that the bottle I have which is marked 9kg may in fact hold less. And when I get it refilled I may think I'm getting more than what actually goes in.
Bugger!
I've just decided that I have more things to worry about than a half kilo of gas.
Wizardofoz said
07:57 AM May 31, 2017
I can't understand how you only get 5 BBQ's out of a bottle???
my 2 bottles last me for the whole 6 or 7 months trip...how many are you cooking for 100 people??!!
brickies said
08:15 AM May 31, 2017
LPG refills , Here we go again .
08:43 AM May 31, 2017
Just don't bring up the weight of them
I just take my 4kg as they come. I get my own 9kg bottles filled and will do as long as I can.
Ron-D said
08:46 AM May 31, 2017
Yeah my bottle on the barby at home lasts for months it might be a typing area and left the zero out
kiwijims said
08:48 AM May 31, 2017
I use a 4 burner B.B.Q. ( cooking for three people ) every weekend, come rain hail or shine Wizardofoz,
I suppose your 2 bottles would last you 6 or7 months if they were only used a few times,
Real helpful comment there Brickies !!!
K.J.
Wizardofoz said
09:20 AM May 31, 2017
K.J.
No KJ, I use it at least twice a week and more, plus my stove and oven are also connected to the bottles...same with the one at home, it lasts me 12 months but then again I am only home for the summer and because I live on the beachfront, my bottles rust and the stores refuse to exchange them again even though they are not out dated.
All I can say to your original question is...YES, you are being 'ripped off' big time!!!
-- Edited by Wizardofoz on Wednesday 31st of May 2017 09:22:29 AM
kiwijims said
09:33 AM May 31, 2017
K.J.
You could do what I did with an old bottle which was out of date by about 15 years, I bought a cheap can of chrome paint from Supercheap, gave the bottle a quick wipe with a wire brush then a spray, looked a treat, then swapped it for a full one ,
This B.B.Q. I have was bought from Bunnings new, maybe that explains why I have only managed to get 5 Barbies per bottle out of it !!!!
K.J.
The Belmont Bear said
09:44 AM May 31, 2017
The bottle I exchanged at Bunnings recently I found that the valve was not seating correctly unless I really over tightened it, I know that because when I finish I always turn the bottle off first until the flame goes out then I shut off the BBQ this time the flame just kept burning with the valve closed. The first time I used the bottle I had difficulty opening the valve because it was shut off so tight - when it runs out I will definately be exchanging it for another one. Maybe you could have also gotten a bottle with a damaged valve seat which allows a slow escape of gas when not shut off tight enough especially if you forgot to close the gas knob on the BBQ all the way - to me that usage still seems to be pretty high even using a 4 burner..
kiwijims said
10:24 AM May 31, 2017
Yes, I had thought of there being a slow leak BB, I did change the regulator and hose a short while ago,
I also ( when finished with the B.B.Q ) always turn off the burner farthest from the bottle first, working back to the first burner, which I leave open until I have turned off the gas bottle, I then listen for the POP of the last burner going out, this tells me the whole line is empty of gas and the bottle is properly shut.
I think it's time to give this B.B.Q the old "heave ho" and buy a new one, ( Not from the Green Shed )
K.J.
Bryan said
11:30 AM May 31, 2017
I reckon you're right KJ, I get a lot more barbies out of my 4kg bottle. I know we're not comparing apples with apples but your bbq seems to be a bit heavy on gas consumption.
May also be a very slow leak from the bottle and if its outdoors the smell of the gas may dissipate very quickly.
01:33 PM May 31, 2017
KJ if your thinking of replacing your old 4 burner you should consider a Webber Q - for 3 people either the Baby Q or the mid size Q2000 would be big enough. You will get a better result and use a lot less gas, I do a BBQ and a roast once a week on a Q2000 with a 9kg bottle and it probably lasts me 3 months, even longer if I used my BabyQ which is in the van. Other people may recommend similar style different brand BBQs but in my opinion cooking with the lid down is definately the way to go in order to keep in the flavour and save on your gas usage. Don't worry the green shed don't sell Webber anyhow so you would need to go somewhere else to buy one usually to a camping shop like BCF.
kiwijims said
01:43 PM May 31, 2017
Thanks for that BB, Yes I've looked at the Baby Q , they sure are a neat looking unit, and very portably which would be handy in our van as well. Now where did I put that Money sack ?????
K.J.
Phil C said
02:38 PM May 31, 2017
Gday all
I have a self made rule not to buy exchange bottles unless Im seriously in the mire for gas, especially from Bunnings.
A mate of mine owns the local hardware, he tells me there is a rule/law/standard someplace that deems 80% fill to be max (I have no clue as to the validity of that). This 80% starts when the white frozen liquid starts to spurt out of the relief valve.
I ask him to fill mine higher so the white spurt is a solid stream. That will do me at least 6 weeks if I use gas in the HWS and cooking on gas. Im told the bottles are tested to way beyond that pressure.
Cheers all, hope you are all thriving.
04:45 PM May 31, 2017
Look on the bright side KJ you may have to spend a little bit more up front but the way your using gas you will probably get it back within 6 months.
bill12 said
04:53 PM May 31, 2017
You are lucky. An exchange bottle is $39.95 on Magnetic island, and $75 at Bamaga , last year......
05:28 PM May 31, 2017
Bill its probably because they have to supply non magnetic gas bottles if they didn't they would be too hard to exchange due to the difficulty of getting them apart just kidding those prices are ridiculous.
kiwijims said
05:35 PM May 31, 2017
K.J.
bill12 said
06:19 PM May 31, 2017
You have no choice, really. if you want to cook for meals or have a hot shower. I take two emptys to townwhen I go, but the barge, 8 klms, is $140 return, and thats for locals. I supose living on an island on the barrier reef is expected to be expensive. Everything is at least 20% dearer.
07:13 PM May 31, 2017
The above post from earlier in this thread gives the background to the 85% 'rule' ... click on above.
cheers - John
mezza56 said
08:15 AM Jun 1, 2017
I bought one of the gauges that indicate the gas level in the bottle , I always check b4 I take them away from where I buy from.
hako said
01:05 PM Jun 1, 2017
If you don't mind me asking, what sort of variation have you found?
JayDee said
06:42 PM Jun 2, 2017
We only exchange if and when we can not gain a refill.
Refilled our bottle today at BCF Griffith for $19.90
We have paid up to $38 for out of the way refills.
It is BCF for us.
Jay*Dee
Cruising Cruze said
07:54 PM Jun 2, 2017
Just wandering
Why can't we with using an adapter just fill up at the petrol station As I believe it's the same gas and at least you can see how many liters you put into the bottle for only 95 cent a liter here
Cheers John
Ps let me know what adapter I need :))
-- Edited by Cruising Cruze on Friday 2nd of June 2017 07:56:40 PM
Craig1 said
09:30 PM Jun 2, 2017
BIG BIG no no John, lots of safety issues or potential for same. Plus a real chance of someone crackin the s...ts with you, fines ,brawls etc
10:13 PM Jun 2, 2017
Sometimes the gas is pure propane but in the cities and large country towns you can get a mixture of propane and butane. If you have butane in the mixture it will mean that the jets in your appliances will be the wrong size.
In addition the filling arrangements of cylinders and auto tanks differ. I believe you can overfill a cylinder with the pumped delivery of the auto pumps.
K.J.
Bugger!
K.J.
K.J.
K.J.
K.J.
K.J.
cheers - John
It is BCF for us.
Jay*Dee
Just wandering
Cheers John
