I have searched the forums and there is nothing recent. My van has a winguard system, that seems to be useless unless you are in a main town or very close by. Can anybody suggest a good system (package) they use, did they install it themselves and is auto finder dishes better than ground mounted self adjusting ones.
thanks
David
-- Edited by dirvine on Sunday 19th of March 2017 09:59:00 AM
KFT said
10:12 AM Mar 19, 2017
G'day David
I am sure others will come along and give you plenty of ideas. In the meantime have a look at the various systems here: www.satplus.com.au/
We use a portable system on a tripod and find that suits us. Others like the simplicity of an auto system.
Frank
01:08 PM Mar 19, 2017
Do a search or look through 'Techies' David, heaps of info on the forum. Make a cuppa and sit back while you read away.
01:49 PM Mar 19, 2017
Have you registered as a traveler ? While you get normal coverage through areal . They generally don't supply sat feed to you . Only ABC and ABS .
Eaglemax said
05:24 PM Mar 19, 2017
We've had 2 altech set top boxes and borh failed in 6 years. Bought a satking and no problems and reboot rarely and when it does it is much quicker.
Sat finder, we bought ours fir $110 on ebay, fine
Finally be aware you can pick up 2 fainter satellites in error. They wi get you only 3 bars. The correct optus satellite will get 9 bars on the finder.
barrie said
08:36 PM Mar 19, 2017
Wiki camps have a sattelite finder easy to use and picture in seconds
Dwilz said
08:47 PM Mar 19, 2017
I have an auto system hasn't failed me to date first thing I do when I pull up is let it do its thing if it doesn't pick up a signal I move to a different position till it does saves a lot of mucking around I suppose I'm just lazy
Bello said
06:52 PM Mar 29, 2017
I have had a satelite system for about 15 years, (I think), changing over to Vast when it started. Have had no trouble so far. We use it a lot so I can set it up quickly. I have the dish on a bracket on the back of the van, a couple of screws and it is ready to set up.
Got to watch the League.
Good luck,
Bello
-- Edited by Bello on Wednesday 29th of March 2017 06:53:05 PM
thanks
David
Frank
Good luck,
Bello
