Is it safe to use a gas regulator in a vertical position. Is it a rule that they have to be horizontal or can they be eitherway. Want to fit a gas heater that has a big end to a companion cyliner.
Thanks.
Landfall said
03:15 PM Mar 6, 2017
Either way, our caravan had the regulator vertical between the bottles.
margjohnb said
04:15 PM Mar 6, 2017
Thanks for that. I think we had a caravan with the regulator like that but always thought it was wrong and not safe.
Tony Bev said
04:40 PM Mar 6, 2017
Not sure of the regulations
The LPG bottle regulator on my old caravan is mounted horizontal
The LPG bottle regulator on my old campervan is mounted vertical between the two bottles
Perhaps one of the members with LPG experience can enlighten us all
hako said
04:47 PM Mar 6, 2017
Apparently it is mounted vertical with the hose pointing down. Link goes to CaravansPlus who have instructions:
Thanks.
https://www.caravansplus.com.au/catalog/help-gas-installation.php
Good Luck.
so Gaseous GAS not liquid gas flows out the valve.
That Gas. Being neither solid or liquid.
Will flow any way you like, without blockage.
