hello everyone, we need more solar panels but do not want to put any more holes in the caravan roof. Does anyone have portable solar and a battery in van. Also, what does everything think of the cheapest 120 watt one that folds up.
Colin Penrose said
03:35 PM Oct 16, 2016
I just used Sikaflex FC11. Stuck my 200 amp solar panel on the roof and it will not move. No holes required.
dave48 said
03:43 PM Oct 16, 2016
Yes sorry the rocket but we don't have holes in our motorhome roof either. Ours is glued and mounted on stands. Would have a huge argument if they wanted to drill holes. The only hole needed is for the cable to come through Dave
Like this https://www.youtube.com/watch?v=C7hM_8tMFvc
-- Edited by dave48 on Sunday 16th of October 2016 03:47:07 PM
-- Edited by dave48 on Sunday 16th of October 2016 03:48:45 PM
Dick0 said
07:06 PM Oct 16, 2016
Sikaflex 221 is the new adhesive from Sika to use for solar panels...aluminium supports to fibreglass roof...and that is the word from the Sika Rep at the Big Shed!
I just bonded my solar panels with Sikaflex 221 and will let you know in 10 years how it's going!
Better than ALL (that's ALL) the other Sika products for caravan (fibreglass) roof use.
Definitely no holes requires!
madaboutled said
10:26 AM Oct 17, 2016
You can even avoid to hole in the roof for the cable by running the cable down the side of the van in a box section conduit then under the floor to where you need it. The conduit can also be glued to the side of the van if need be. Sikaflex.... "bolts in a tube!"
08:32 PM Oct 17, 2016
I run ours down the fridge vent . It can also be installed down any roof vent ..
