I cooled off on the house up in the Flinders Rangers. Had a male friend go up there and have a look at it for me. It is full of white ants (has just been treated) one complete wall needs coming out and then he said it also had asbestos.
I was disappointed but guess ever thing has a reason attached to it. Wasn't meant to be.
But funny thing is he found a nicer little home in the Southern Flinders (well so he says) in a little town called Laura and I just love that name also.
So will go and look at that next weekend.
If I like it and buy it I might still keep my van so that I can still go up around North (SA).
Life wasn't meant to be easy!! lol.
You will all still be welcome wherever I move to!
You know - tomorrow will change again.
Helen
CC Bear said
07:40 PM Oct 3, 2016
Tomorrow will always change we just have to pick our own current to paddle in. Hope this one is the one for you Helen. Cheers
Hewy54 said
08:12 PM Oct 3, 2016
Worth living in Laura just to be where Golden North icecream is made.
Lovely little town, not too far to duck down to the big smoke for supplies if needed, and at the gateway to some great country.
adreamer said
10:40 PM Oct 3, 2016
Hewy54 wrote:
Worth living in Laura just to be where Golden North icecream is made. Lovely little town, not too far to duck down to the big smoke for supplies if needed, and at the gateway to some great country.
Thanks hewy. I forgot about the ice cream, maybe they will hire me as a taster, get the sugar in my brain going!
Yes, the country around there is un spoilt - not sure for how long though, seems to be lots of 4x4's tearing up the roads.
Hewy54 said
08:24 AM Oct 4, 2016
Such a pity the Stone Hut bakery is closed at the moment.
Pies there were so good we used to drive up from Gawler just to get some pies.
Chellbells said
01:53 PM Oct 6, 2016
Why not buy a 4x4 motorhome to last another 20 years and forget buying a house? Just a thought. We're not here for a long time - sounds like you would be very sad to give up your van. Marie
iana said
02:25 PM Oct 6, 2016
The idea that I have o follow up, is that in some counties, you can build a certain class shed, ceilings, sewage, running water etc. And live there. Just make it so you can park the van or motor home along side and walla you have a home base with storage, but also take off when ever you feel like it.
adreamer said
06:16 PM Oct 6, 2016
Well, I have thought of that and sometime back looked at a block in Adelaide hills with a nice big shed on it but had no power or septic. Nice small town only 65klms from Adelaide. Flat block and nicely treed. $65,000
Power was on the fence line. Water is connected, both pretty essential I think.
Any other ideas would be good to hear about.
Mind you if I did that I could never afford to build on it. I could upgrade my van though.
Helen
-- Edited by adreamer on Thursday 6th of October 2016 06:17:21 PM
Krusty said
07:34 PM Oct 6, 2016
Yep, did it.
Built a 6m x 12m carport. Enclosed the western end of 6m x 3m which was then dividen into 2. One was bathroom, vanity and composting toilet. The other laundry and storage. Drive through on the eastern end of 6m x 3m to park the caravan with a 6m x 6m breezeway in the middle with outdoor setting and outside kitchen. Eventually got rid of the caravan and enclosed the eastern end which is my bedroom and living space. Camperd up the Landy which is my get-away vehicle now.
Couple of rainwater tanks with an instantaneous LPG (8.5kg) HWS and the benign central Queensland coastal climate and the living is cheap and easy.
beiffe said
10:57 AM Oct 8, 2016
Hi have a look at blocks around Mannum. Seem cheap and close to Adelaide and on the Murray
adreamer said
03:00 PM Oct 8, 2016
What do you call cheap?
The riverboat sounds like fun, have know people to it and never turned back.
Hope you also enjoy it!
Helen
macka17 said
11:48 AM Oct 16, 2016
Riverboats aren't cheap. If any good.
Also the Annual maint, is not to be laughed at.
if you want to keeep it at value and not sink on you
A lot have.
Check up thoroughly first.
Slipping fees. Berthing fees at Marina.
Antifouling and any repairs.seals bearings renewing regularly.
to keep her afloat.
Not as cheap as standing on a pr of wheels.
beiffe said
01:26 PM Oct 16, 2016
Hi everything has cost. Full slipping with painting of pontoons, insurance inspection and environment certificate etc was $1600 mooring in a locked marina with every thing except power included(I am going full Lithium similar to bus so after set no cost)
Fuel won't be much as I can steam for 1 hour for 3 lines of petrol and insurance was $360 for year.
Everything has a cost it depends on the life that cost gives.
08:10 PM Oct 16, 2016
You sure sound like you know what you are doing Brian, well done. I agree - would be fun for sure.
Chellbells said
01:00 PM Oct 26, 2016
That is what I want too.
Chellbells said
01:03 PM Oct 26, 2016
That is what I want too. I would so love to know what States of this country you can still do that in.
Chellbells said
01:04 PM Oct 26, 2016
That sounds like a flood zone?
Footprints said
05:57 PM Oct 26, 2016
There are quite a lot of those type places available to purchase already set up for van and facilities. Can be found in most states, they are usually marketed as Weekenders in order to get around the legalities of not being for "permanent" abode. With a caravan or similar on wheels it usually satisfies the Local Shire regulations. Look on realestate.com for the area of your preference. Only yesterday I discovered at least ten in my area of preference on land varying in size from one acre
Footprints said
06:02 PM Oct 26, 2016
There are quite a lot of those type places available to purchase already set up for van and facilities. Can be found in most states, they are usually marketed as Weekenders in order to get around the legalities of not being for "permanent" abode. With a caravan or similar on wheels it usually satisfies the Local Shire regulations. Look on realestate.com for the area of your preference. Only yesterday I discovered at least ten in my area of preference on land varying in size from one acre to in excess of fifty acres. Happy hunting. cheers Allen
I'mmmmmmmmmmmm Back!
Helen
Helen
Helen
A lot have.
to keep her afloat.
P.S. don't know what happened on previ
