I am thinking of getting an inline water filter to fill up my caravan water tank Has anyone got any useful info i.e which is the best one?
rgren2 said
01:58 PM Sep 28, 2016
albro wrote:
Hi folks,
Nailed it. Well I use BEST.
The link I keep posting won't work. Google BEST filters.
-- Edited by rgren2 on Wednesday 28th of September 2016 01:59:59 PM
-- Edited by rgren2 on Wednesday 28th of September 2016 02:01:37 PM
02:15 PM Sep 28, 2016
Another B.E.S.T filter user here. You can get them on evilbay as well. Most good caravan accessary places have them.
Keep safe on the roads and out there.
Geeco said
02:23 PM Sep 28, 2016
Another vote for B.E.S.T filters and Hoselink fittings.
albro said
02:33 PM Sep 28, 2016
Thanks guys - just the replies I was hoping for!!
macka17 said
03:41 PM Sep 28, 2016
Hi.
I just use a solids filter for inlet.
and have a dual, carbon/ceramic? filter in line from tank to tap.
dishlicker said
06:28 PM Sep 28, 2016
Hi Albro yes as already said best is best
Peter and JudyH said
10:53 AM Sep 30, 2016
I have just got the new van home and setting it up for 1st shake down trip.
I did a lot of research and came up with BEST as well.
I'm off to pick one up today.........
albro said
02:56 PM Oct 1, 2016
Many thanks for the info folks!
I have ordered a B.E.S.T. on eBay $103.90
mjt57 said
03:54 PM Oct 1, 2016
I got a B.E.S.T. filter too.
I drained my tanks then refilled them through the filter. Then I ran a host from the tap on the van back into the tank filler pipe and using the water pump I recirculated the water for a couple of hours to "polish" it as the BEST manual says.
Certainly, I couldn't taste any funny or odd tastes in the water afterwards.
I'll run through the same procedure again before our next trip.
Grubbygypsy said
09:10 PM Oct 1, 2016
I use a dual 1 micron filter set into the van (paper first, carbon second). Then there is an everpure 0.5 micron to the drinking water tap - from that I only make/drink distilled water, so I have a very steady quality of water for ingesting, no matter where it hails from. You can't be too careful of water quality with regard to a van and yourself. I've already had to replace one check valve due to heavily mineralised northern water. The old govvie feed us all sorts in the town water too!!! Shocking stuff.
Tony Bev said
10:32 PM Oct 4, 2016
Thanking everyone who mentioned B.E.S.T. water filters
I was unaware of their existence
After reading up on them, I have just purchased one locally, at home base
After purging the carbon dust, as per the instructions I took a sip from the hose before filling my tanks Also as per the instructions the water had a metallic taste, when I took a sip from the hose
I have one question Is the metallic taste always there, or does it fade away
Hi folks,
I have one question
