I've seen numerous posts about adding Sodium Percarbonate to toilet cassettes, and I do the same with excellent results.
I am thinking of installing a grey water tank about 45lt in size.
Do you get the same results adding SP to grey water tanks, otherwise, what would you use to neutralise grey water in tanks other than the commercially available "bacteria eating" chemicals?
09:27 PM Aug 21, 2016
Yes we just add a desert spoon heaped with Nappysan substitute if any smell starts.
Weedpharma said
09:37 AM Aug 22, 2016
A friend that has been caravanning for many years told me that SP damages the dunny seals. Has anyone heard of this?
His was not personal experience.
Weedpharma
09:42 AM Aug 22, 2016
Been treating for 2 years no issue . Btw it's the active ingredient in nappy San . Plus it's used in cleaning beer lines . It's an oxidising agent.
Dick0 said
12:50 PM Aug 22, 2016
Great...looks like SP will work in toilet cassette and grey water tank...only need the one "chemical" for both.
Thanks for the help everyone, much appreciated.
Peter_n_Margaret said
06:49 PM Aug 22, 2016
Sorry, but Sodium per carbonate mostly won't do much in grey water. It has little or no effect on the fats present which are the biggest problem and no effect on the detergents.
For effective treatment of grey water you need to use one of the enzyme products. We don't bother. Better just to get rid of it on a more regular basis.
Dick0 said
07:19 PM Aug 22, 2016
Peter_n_Margaret wrote:
Sorry, but Sodium per carbonate mostly won't do much in grey water. It has little or no effect on the fats present which are the biggest problem and no effect on the detergents. For effective treatment of grey water you need to use one of the enzyme products. We don't bother. Better just to get rid of it on a more regular basis.
Cheers, Peter
Thanks Peter, was wondering what to do if unable to empty tank before, say, 3 days. Does the grey water turn into black water and is there a simple & cheap way of avoiding that?
What would be getting rid of it on a more regular basis as a time frame be, and what would the condition of the grey water be like then?
I have no idea about storage of grey water and the best way of disposing stored grey water. Presently I don't store grey water but drain it with a 10mt hose without trying to be a pest to others.
So, I am hoping those who store grey water can give me their experiences and advice.
GerryP said
08:05 PM Aug 22, 2016
We have a grey water tank and even if we regularly empty it, it can eventually still start to smell a bit. When this happens, we add some bleach. This works quite well, especially if you can add it with some water, prior to hitting the road again. By the time you get to your next destination, or a suitable dump point, it has sloshed around nicely and the smell is no longer there.
We also tend to leave the plugs in the sink and hand basin to stop any odours from rising up from the drains.
We haven't tried SP (Napisan), but I can't see any reason why you couldn't try it.
08:28 PM Aug 22, 2016
Dick0 wrote: Does the grey water turn into black water and is there a simple & cheap way of avoiding that?
There were quotes from various authorities claiming that storing grey water too long turns it black a few years ago. These claims have subsequently been rebutted. The previous claims have been shown to be false by proper testing of stored water.
Dick0 said
10:31 PM Aug 22, 2016
When I have used the tank for a while and experimented with all the suggested additives I will post my experiences and opinions on the different additives with outcomes. Still a bit confusing for me at the moment but time will no doubt reveal all.
Thanks for your suggestions, opinions and recommendations.
05:47 PM Aug 23, 2016
We have been using the generic brand sodium percarbonate products for over four years - no problem at all with our dunny seals. And we put it down the drain - and, if nothing else, it kills the odour from the drain. Can't hurt, I wouldn't think. Capful is all you need for most applications.
Tony Bev said
07:02 PM Aug 23, 2016
Another traveller gave me the tip of:-
Have the grey water tank half full Add a bottle cheap white vinegar to the to the grey water tank Go for a good long drive so that the water sloshes around Empty the grey water tank I have done this once in three years
I have no problem using Napisan type products (of above 30% SP) in the cassette toilet I put the Napisan in first, and then the water When I close the sliding valve, between the bowl and cassette, I flush about an egg cupful of water over the valve seal If any Napisan was still clinging to the sliding valve seal it will hopefully not dry the seal out
I have no idea about the cost of a slide valve seal, but it looks easy enough to replace
Dick0 said
12:40 AM Aug 24, 2016
Yes, SP seems to work well in the toilet cassette, I suppose, because no other detergents or food fats present. But I am understanding that grey water is very different due to detergents and food fats, which turns to black water after a day or so. I know you can get enzyme chemicals that eat the grey water bacteria but are very expensive. So wondering if SP (or other cheap additive) will stop the grey water turning black and allow the grey water, whilst treated, be dumped safely in the countryside after a day/two/three? I figured there should be numerous nomads in the playground with extensive experience in treatment and disposal of grey water tanks and post how they dispose the contents of their tank. Toilet cassettes I am very clear about...use a dump point. But grey water?
09:31 AM Aug 24, 2016
DickO - use a dump point - of course what some who advocate this haven't thought of the holding tank of the dump point (unless connected to mains sewage) will fill very quickly, requiring more frequent emptying by the council, free camp etc., who provide it - Port Augusta motorhome camp near the sports club have found this, if you aren't staying there, they charge you to use the dump - fair enough I say, stayers have to pay (minimal cost).
03:05 PM Aug 24, 2016
Dick0, you did not read what I posted back at 20:28 Aug 22, 2016 did you.
Dick0 said
05:20 PM Aug 24, 2016
Thanks PeterD and others...I think I may be too overly concerned about the issue. It may not be such a serious problem as I imagined.
Weedpharma
