I thought I would start a new thread. I would like to know how the gas system works.
What keeps the gas flowing when the burner is alight?
03:39 PM Aug 21, 2016
Do you have a handbook for it - use this link - You may be able to work it out from the parts list.
aussie_paul said
04:57 PM Aug 21, 2016
Thanks Peter, yes I do have that manual. I can see that the gas is controlled by the electric solenoids, BUT I do not understand where the signal to the solenoids comes from. I am only used to pilot lights with thermo coupling. Hopefully there will be someone who can explain it to this simple lad.
macka17 said
09:44 PM Aug 21, 2016
"What keeps the gas flowing when the burner is alight?"
Gas normally travels/comes from pressure preloaded in bottle.
The solenoids/jets etc.
Just control flow as it is propelled through them
Off.on. High. low.
It will always move away from bottle, if exit point opened
until bottle empty.
aussie_paul said
10:07 PM Aug 21, 2016
The solenoids/jets etc. Just control flow as it is propelled through them Off.on. High. low. It will always move away from bottle, if exit point opened until bottle empty.
You have obviously misunderstood macka. What signals the solenoids to stay open when the burner is going? In other words the safety issue that stops gas flowing when the flame accidentally goes out from a wind gust etc?
wal1 said
10:15 PM Aug 21, 2016
Hi Paul.
Just gone through this my self, had trouble lighting and keeping going. i found a service manual on line that gave some info.
The gas supply solenoids are controlled by a micro processor, along with the ignition sequence.
The probe that goes into the combustion chamber, serves two purposes. The high voltage side provides the spark to ignite the gas, and the negative or return probe, when sufficiently heated by the flame sends a very small current to the micro processor, this in turn serves as a flame sensor. It took some time to get my head round this.
Now in order for all this to work, the probes have to be clean, with no carbon build up, so after stealing my partners emery boards, it now works. I will try to find the manual and link it.
Wal
aussie_paul said
10:30 PM Aug 21, 2016
wal1 wrote:
Hi Paul.
Wal
Great Wal, many thanks. I hope you can find that link.
I have this curse of always needing to know how things work.
Although, this curse has served me well with type 1 Diabetes since 1970.
-- Edited by aussie_paul on Sunday 21st of August 2016 10:43:48 PM
macka17 said
03:05 AM Aug 22, 2016
Sorry Paul.
I was going by that part of the question.
Gas flow is pressure.
I thought the other part of it was some sort of thermocouple?.
Temp, operated.
wal1 said
08:23 AM Aug 22, 2016
Paul, that's the one.
aussie_paul said
08:56 AM Aug 22, 2016
macka17 wrote:
Sorry Paul.
I was going by that part of the question. Gas flow is pressure.
I thought the other part of it was some sort of thermocouple?. Temp, operated.
No worries Macka, I was only aware of the thermocouple system, and was wanting to know how the SW6DEA system worked.
macka17 said
12:50 PM Aug 22, 2016
We all live and learn mate.
Everybody (somewhere) knows more than you, me, them.
I'm trying to get my head round a new 55in 'smart" tv I bought coupla days ago.
Jeez it almost wipes your a-se for you.
It's definitely a lot smarter than me. Electronically. BUT..
I still control the OFF switch.
adrian foley said
07:35 PM Aug 23, 2016
It is called flame rectifaction,thermostat calls for heat computer chip ,scarico ,phillips or other type direct power to solenoids these open at same time spark to burner ignties gas at burner.there is a sensing rod at flame which detects heat and convert to micro farrod electrical charge and send back to control box.once this is done the sparker stops and burner keeps going until thermostat senses that it has reached temp.anyway that's a rough generalization.
aussie_paul said
07:45 PM Aug 23, 2016
Thanks Adrian, much appreciated.
aussie_paul said
09:41 PM Aug 25, 2016
Ok, I cleaned the electronic starter probes. I then fired it up and took video.
You can hear it stop and then relight, then stop and relight again and then it kept going.
That could be because I had allowed air into the line.
I will test it again tomorrow after mounting the flue.
Off.on. High. low.
until bottle empty.
Hi Paul.
Wal
p.s. this may be it. https://www.rexandsonsrvs.com/manuals/Suburban_Water_Heater_Service_Manual.pdf
Temp, operated.
https://youtu.be/PkVhb8tJAmo
I never had the chimney flue attached.
-- Edited by aussie_paul on Thursday 25th of August 2016 09:42:14 PM
