I have a Suburban water heater which work great on 240 V but on Gas it stops after about 5 seconds, keeps trying to start but stops almost all the time.
Any clues on what the fault may be.???
Dick0 said
06:28 PM Aug 20, 2016
Assume other gas appliances are working...Stove & Fridge on gas. If yes, check gas tap open to Water Heater, otherwise check if jet is blocked.
dragonfly1 said
06:59 PM Aug 20, 2016
The gas jet could have a spider in it happens quite often
Thanks I will check for blockages or spiders, but yes all the other gas appliances work.
Occasionally the Hot water system works as well but mostly not.
Perry
Two Strays said
09:24 AM Aug 24, 2016
Hi Perry
Rub you finger across the jet out let , it does not work, push a very fine wire into the hole to clear any debris. Still no go, get it checked out.
Perry said
10:31 PM Aug 26, 2016
Thanks for all the replies, I will drag the van out tomorrow and let you all know how I go.
Perry
GerryP said
09:07 AM Aug 27, 2016
Hi Perry,
Just had the same thing on both our van, as well as that of a friend. There's two things you need to do...
1. Using an air hose, blow out the combustion chamber and the fire tube. You can do this in situ without dismantling anything. You will probably blow out a lot of rust and scale.
2. This bit though is the more important step. Unplug the fat red wire from the spark igniter/flame sensor and remove the sensor. There's one screw to undo and it pulls straight out. Using a fine emery or even a nail file, clean the tips to remove any scale, back to a bright-ish metal surface. DO NOT bend or adjust the rods or the gap between them. Replace the unit and reconnect the wire (spade terminal) making sure it is clean and tight.
That should fix it for you for another 4 or 5 years. Good luck.
Perry said
11:14 PM Aug 28, 2016
Thanks Gerry, I will try blowing it out with a air hose.
Perry
GerryP said
07:43 AM Aug 29, 2016
No worries Perry. But the second bit, cleaning the electrodes is the more important thing to fix the problem though.
Dragonfly1
My thread re same/similar problem.
http://thegreynomads.activeboard.com/t62526988/hot-water-problem-on-gas/
Perry
Hi Perry
Perry
Hi Perry,
Perry
Good luck mate. :)
