I ask again!! What is/does cause a gas explosion in a van??
Seems to be too many recently and I'm sure in the past.
Helen
stoney123 said
04:20 PM Aug 19, 2016
get a gas leak detector. also have to watch for carbon monoxide poisoning from gas heater.
old hoses, valves, old cylinder, leaks ie oven,stove,heater,fridge...hence need for detector.
Yuglamron said
04:46 PM Aug 19, 2016
The gas itself is odourless and colourless and heavier than air so settles low down. Very slow leaks can settle without being sniffed so as Stoney says a good detector is essential.
Just as an aside I lived in Scotland for a couple of years near a place that manufactured the "Smell" that was added to the gas.
They had a major leak and the emergency services were activated. Police Firies ambos. the whole shebang.Police touring with loudspeakers telling people to turn off pilot lights have no naked flames.
Seems the plant didn't inform the authorities that it was just a smell and not inflammable in itself.
The name of the Plant was "Lurgie" as in the dreaded.
I kid you not
Tony Bev said
05:24 PM Aug 19, 2016
Helen
Hello adreamer
I will assume that no Gas Fitters have seen this thread, therefore from a layman point of view, I will attempt to answer your question
There are many areas inside the van the gas could accidently start leaking from, such as a hairline crack on the supply pipe, any joins along the gas pipe which are inside the van, the control switches of the gas appliances, etc.
The leaking gas is heavier than air, it will accumulate in the lowest area it can find The smallest leak, over time, will result in a large enough accumulation of gas to explode when it comes into contact with a spark or flame
In a van with a three way fridge, while it is working on gas, there is always a flame burning, which will cause any accumulated leaking gas to explode
The manufactures put in a smelling agent (Ethyl Mercaptan). To ensure that a person will be able to smell leaking gas Unfortunately when a person is asleep, or has the sniffles, there is a good chance that they will not smell leaking gas
Sometimes there is not much left of the van after a gas explosion, to pinpoint exactly what happened This is why we sometimes just have to guess, how did it happen
Some people I know, have decided that as they do not open their fridge at night, they will turn it off, to save gas I will assume that if the gas bottle is also turned off, there would be no chance of a gas explosion
01:33 AM Aug 20, 2016
Leaks and bad ventilation . Cause ? A spark or baked flame .. Wow ..
brickies said
06:55 AM Aug 20, 2016
How many on this forum cover the vents on their RV to kept the cold out , I have read lots of post on the forum from member who do so .
Izabarack said
08:24 AM Aug 20, 2016
There is a big difference between a gas bottle exploding and pooled gas igniting. It seems that many gas bottle explosions are actually the result of a leak building enough air/gas combination for a spark of some sort to set things off. A gas detector is a very good idea. I know of two potential situations where the problem was simply caused by a vibration caused crack in a line leaking into a confined space.
Best practice seems to be to ensure all vents are clear, like the door vent down low, and to turn the gas off at the bottle as a regular practice. We often turn the gas off at the bottle if not just before meal time and have a camping stove on the outside table for making a cuppa during the day. Our hot water system only needs to be on for less than ten minutes before we shower, then off again at the bottle.
Iza
Moorey said
09:37 AM Aug 20, 2016
Some of my remarks have already been posted and I am not intending to disregard them.
There is a difference between an explosion from the ignition of gas and a gas cylinder exploding. If there is insufficient ventilation when there is a leak then as stated previously the gas will pool from the lowest point and rise. When the gas/oxygen mixture comes into contact with an ignition sauce you will get an explosion due to the confinement whether it be in a house, caravan or car. Ignition sauce could be the pilot light or any device that has an electrical switch that that is turned on and off as a function of an appliances operation. If this incident occurred outside the caravan then there would be a sudden fire but not an explosion. VENTILATION IS THE KEY WORD and one should also be vigilant with maintenance and periodically check for leaks. ALWAYS check for a seal when replacing a gas cylinders by using a small spray bottle with soapy water.
For a gas cylinder to explode it has to be punctured or involved in a fire where the heat is sufficient to weaken the cylinder wall. A cylinder when heated will breach the safety valve and the escaping gas will ignite if there is an ignition sauce otherwise it will dissipate into the atmosphere. If the cylinder wall is breached and there is an ignition sauce then a BLEVE will occur and the resulting fire ball will depend on the size of the cylinder. (Bulk Liquid Expanded Vapour Explosion) Gas is compressed into a liquid form in the cylinder and expands to a vapour on release and conveyed to your appliance through a regulator to ensure a safe flow. Gas is an efficient, low cost fuel and is only dangerous when not maintained as is electrical and fuel appliances.
If you smell gas immediately turn off the cylinder and move clear until it is checked by a licensed operator which is the same if you have a fuel leak or an electrical short involving high voltage.
I hope I have not rattled on too much but attempted to answer the original question a simple way. Sometimes when we answer questions we forget that not everybody has our particular understanding of what we are explaining and are afraid to seek clarification for fear of following postings.
Moorey
adreamer said
09:45 AM Aug 20, 2016
Moorey
Thank you Morrey, Correct I am a mere female, you made it very clear for me.
Helen
Brenda and Alan said
02:59 PM Aug 20, 2016
This belief that leaking gas does not mix with air but settles to the lowest level and remains there is just plain wrong. For a gas "explosion" to occur the gas MUST be mixed intimately with air in the correct proportions to burn. All gases mix together in all proportions and do not remain separate as in oil floating on water. The only time LPG will settle and flow to the lowest point is when the leak is massive and there is insufficient time for it to mix with air. Have a look at the Elgas web site for further info on the properties of propane and the air gas ratios required for combustion to occur. Also gas cylinder "explosions" are very very rare and only occur under extreme heat when the pressure relief valve on the cylinder cant dump the contents quick enough and the cylinder bursts . Almost all reports of gas cylinder explosions are in fact not and the cylinders are undamaged. Just poor reporting.
adreamer said
08:15 PM Aug 20, 2016
Hi Brenda and Alan
If you read my original post, I never mentioned gas bottle. Just gas explosion and you answered my question pretty much as did the other contributors.
Guess Gas can be deadly if not respected as it should be.
iana said
08:47 AM Aug 21, 2016
Sorry adreamer, but check your title!, I thought the same as Brenda and Alan.
adreamer said
11:04 AM Aug 22, 2016
Sorry, I did say GAS BOTTLES in the subject line.
But I know, you know the bottles do not explode by themselves.
Helen
iana said
07:38 PM Aug 22, 2016
Actually "Guess gas" is harmless, just leaves you in a confused state. Isn't the English language a funny thing. On a lighter note, a few years ago in Perth, at a new restaurant , a couple of fellows wanted to rid the place of c**kroaches (Oh boy!), so they set off a heap of those bombs and sealed the place off. Unfortunately there were gas stoves and with gas stoves there are pilot lights. They blew the restaurant to kingdom come.
07:54 PM Aug 22, 2016
Sorted the roach problem though.
Spook said
07:38 AM Aug 23, 2016
One should not be using a flueless gas heater in a caravan.
Actually, the correct term is Boiling Liquid Expanding Vapour Explosion - I was in the engineering design office of a major National Fire Protection company for over 3 years.
BLEVE's were mostly due to overturned road tankers or rail tankers totally surrounded by fire, which 'boiled' the contents, greatly expanding the vapour inside until a tank seam ruptured, then BAM !
oldtrack123 said
04:04 PM Aug 27, 2016
Not I
Unlike natural gas, propane is denser than air. It may accumulate in low spaces and near the floor
It does have to mix with air in the right proportions for an explosion to occur, but that mix must be within range of ignition source
It can separate out from the air & settle, if no ignition source is in proximity to the correct mix
Any explosion must be due to a gas leak of some form,
The leak could be from:
faulty joints
Cracked pipes or perished hoses
faulty control taps /valves
burners not completely turned off or accidently slightly turned on.
Equipment not fitted with or a faulty flame cutout, which for what ever reason are allowing gas flow but no flame.
The work that NON licenced gas fitters can legally do ,is very limited for good reasons
Gas & electricity are highly regulated as both DO cause deaths & severe injuries.
All vans /motor homes etc shall, by design , have a degree of fixed through ventilation ,especially one at floor level [which should not be covered] &roof level & the areas are determine by the gas burning devices in the van.[That does not include the 3way fridge whose rear shall be sealed from the van interior & shall have it's own ventilation]
The floor level one is often in the step well ,that being the lowest point
Most 4 Season hatchs do not fully seal ,& can give the required area of roof ventilation to allow through ventilation
Those areas should never be sealed!!!
Any smell of raw gas should be quickly investigated
-- Edited by oldtrack123 on Saturday 27th of August 2016 04:25:56 PM
-- Edited by oldtrack123 on Saturday 27th of August 2016 04:33:21 PM
08:00 AM Aug 28, 2016
Sorry oldtrack123 but once gasses are mixed they do not separate and settle in different layers. It takes very expensive equipment to separate different gasses as gasses. {not as liquids}
Alan
macka17 said
11:29 AM Aug 28, 2016
99% of Gas explosions are the gas leaking.
I've seen two actual bottle explosions. Both in mid '60's early '70's on construction sites. One was a "tea room in old wartime bomb shelter in UK Winter. ALSo bottle storage for site (100lb bottles.)
First one. Line to "being used" bottle split. Flame travelled to bottle. blew valve off. This BOTTLE explosion blew off a solid reinforced concrete bomb proof roof and landed it 10 ft away. Only 2 other bottles blew.Rest were ok and still full.
Those other 2 bottles, closest to blast. blew of top valves. gas jetted out and mixed. Boom. There were 2 separate distinct explosions. I was there but not in shelter.
This was findings for experts afterwards.
Other one. fire in storeroom. Small bottle overheated. Boom. Instant NO storeroom,and steel shrapnel pieces found up to 100 yds away. embedded in whatever.
Leaking gas. an overall explosion in all directions. then gone.
Bottle explosion. Primarily from one end of bottle in that direction with some lethal shrapnel from source.. and doesn't that remaining part of bottle travel at a rate of knots in opposite direction.
Gas leaks are a mix of oxy and gas to dangerous proportions then boom all gone..
Bottle leak is a progressive 'expanding" type of explosion as more gas eats more oxxy and prolongs the boom. (in a microsecond) Compressed and expanding/mixing. rather than one premix at air pressure
all going off in one hit.
One an instant flash and damage caused. finished. T'other a more prolonged flash/pressure wave with a lot more damaging effect overall.
One of the courses I did in army on armoured recovery.(ARV/BARV) was controlled explosives and HOW to hopefully control the different types of materials used.. Using whatever was avail.
And DON'T hold the sealed end of ANY det(onator) for more than a few seconds.
instant finger loss.
Some should read up on these things. Very interesting. Just for increasing your knowledge.
-- Edited by macka17 on Sunday 28th of August 2016 11:36:36 AM
oldtrack123 said
02:43 PM Aug 28, 2016
Hi Allan Without trying to start a bunfight I suggest you do a little research on Propane I am sure you will find many sites that state: Propane is heavier than air If there is a leak it will tend to accumulate in the lowest spot. You will also that is the prime reason for all vans & motor homes etc to have a PERMANENT vent at the lowest point
You will also find that the area of the permanent vents is determined by the combined possible gas output of ALL gas appliances installed
Perhaps others with doubts should do the same.
Of course if there is sufficient air turbulence in the situation , all the propane may not settle,
You will also find that many explosions on boats are due to the propane settling.
I am well aware of how all the gases in air for example are separated out .
Compressed to extremely high pressure to form a liquid, then boiled off @ different temps& collected[including the rarer gases , such as argon ] the method works because each gas has it's own point at which it changes from liquid to gas
-- Edited by oldtrack123 on Sunday 28th of August 2016 02:56:37 PM
09:09 AM Aug 29, 2016
Propane is not heavier than air, a Kgm of propane is the same weight as a Kgm of air. The specific gravity of propane is higher than air, but this does not change the fact that all gasses mix together in all ratios.
Propane will only burn in air if the gas concentration in the air MIXTURE is within the range of 2.15 to 9.6 %. If the concentration is outside these limits it will not burn. So if your propane is sitting on the floor only the surface in contact with air will burn, hence no explosion. For an explosion to occur requires a propane air mixture within the above ratios not gas on the floor and air above. This is more likely to occur due to a small gas leak in an enclosed space such as a caravan rather than a major than from a major leak.
As a safety measure a smelling agent is added to the gas which can be detected by the nose long before the concentration of the gas air mixture reaches flammability levels. Detecting this smell under normal operation is an indicator the gas system needs attention and should not be ignored.
Alan
oldtrack123 said
01:34 PM Aug 29, 2016
Alan
OK , Allan , All the sites that say other wise must be wrong
A long post telling most of us facts we already know
All those vans & motor homes with the mandatory vent at the lowest point should just seal them off ,that will save dust getting in
Did you bother to do a bit of googling???
-- Edited by oldtrack123 on Monday 29th of August 2016 01:38:30 PM
oldtrack123 said
01:49 PM Aug 29, 2016
For those who want FACTS ,this should be classed as a reputable site & there are many others along the same lines if you do a good search.
There are other AUSTRALIAN sites, & I know one ,specifically refers to slow leaks ,as from a cracked pipe , in enclosed spaces
ALL make the clear statement that PROPANE gas is heavier than air!!
But make sure you are reading about AUSTRALIAN PROPANE
Do not just go to Wiki
-- Edited by oldtrack123 on Monday 29th of August 2016 01:58:14 PM
02:30 PM Aug 29, 2016
Let's sticky this to the extension cord thread ..
oldtrack123 said
03:40 PM Aug 29, 2016
I throw another example into the picture
Why do the Standards NOW require a specified sized opening at the lowest point in the gas bottle storage area .
The usual vented door , with the vent grills not at right at the bottom[ if fitted ]is no longer acceptable
05:55 PM Aug 29, 2016
My data did come from Elgas web site and it and the others are wrong to say propane is heavier than air. The correct terminology is specific gravity not weight.
Alan
iana said
06:55 PM Aug 29, 2016
A parachutist jumps out of an aircraft way up there, and finds his parachute won't open, he passes another guy going up, do you know anything about parachutes he calls out, no said the other guy, do you know anything about gas leaks in caravans.
Dickodownunder said
10:00 PM Aug 29, 2016
10:10 PM Aug 29, 2016
Gas needs oxygen to explode . Unless superheated ? The bottle itself can't explode . If it leaks into a volume mixed with oxygen / air ? It's abomb !!
Helen
I kid you not
Hello adreamer
There are many gas detectors a person can buy. This is a link to just one of them
Iza
Moorey
Helen
Hi Brenda and Alan
Helen
Not I
faulty joints
Alan
First one.
Other one.
Boom.
(in a microsecond)
Hi Allan
Alan
http://www.elgas.com.au/blog/453-the-science-a-properties-of-lpg
Alan
