Having a problem with redarc towpro elite.when connecting up to caravan cannot get it on to auto mode.only manaul mode. The light only flashes on auto mode.but after travelling for about an 1 hour and stop .when you start up again it goes to auto straight away. But not first thing in the morning.
patrol03 said
06:41 PM Aug 13, 2016
I would suggest you contact Redarc with your problem as they are only too pleased to help.If you have wired in the unit yourself recheck the connections and make certain the unit is hard mounted under the dash and not just attached using cable ties. Cheers
