Recently it went to switch on the hot water system, and found the on/off switch behind the outside cover was stuck in the off position, so I sprayed some lanolin oil on the switch and surrounding area and operated the switch a few times and found it was moving again.so I turned on the system and found the water heated up as per normal . The following morning after I had a shower I noticed the water did not reheat until I pushed the reset button , then I could hear the unit working again, I checked over a couple of days and found that every time the heater had heated up the water to the correct temp and the thermostat had cut of the power to the heating element it would not reheat the water unlit I pushed the reset button . Could anyone give me advice as to what the fault could be .
kezngaz said
03:15 PM Aug 2, 2016
Hi carl44.
Ive only just recently started to use a hws and are slowly working out how things work.
In your case, firstly you need to find out what is actually being reset.
How hot is the water getting? I found a tap under our van which controls the heat on the outlet to the taps inside.
Back to the hwt, is there a temp sensor thats tripping out or a timer?
Ill look fwd to others views as im still learning myself!!
Kezngaz.
Kezngaz.
