Hi all. Was hoping somebody could shed some light on a problem im having with the above charger.
When i first switch it on the display reads r05.
I never noticed if this came up before the darn thing no longer charges..
The display adter a few seconds reads 0.0v, the only info i can gather is that it cant sense the battery.
Has anybody else had similar experience?
I kook forward to the constructive replies!!
Kezngaz.
patrol03 said
07:09 PM Jul 29, 2016
Hi Kezngaz.is your battery dead flat? Have you firstly set the type of battery e.g. lead acid,AGM etc ?
kezngaz said
07:37 PM Jul 29, 2016
Hi Patrol.
Yes batteries are fine.
Ive found the problem and fixed it.
When ive cut the leads down in length to tidy the battery area i never realised that there are sensor wires running inside the battery cables and they never got stripped enough to make good contact.
Ive recrimpped them and alls good.
The display was showing either dead flat batteries or as it turned out, not sensing the battery.
Thanks for.your reply.
Kezngaz.
macka17 said
11:00 AM Jul 30, 2016
Hi.
I've had a coupla Projecta items over the yrs.
None worked. reliably for long.
Not the best Quality wise.
kezngaz said
10:18 PM Jul 31, 2016
macka17 wrote:
Hi.
None worked. reliably for long. Not the best Quality wise.
Kezngaz.
Hi Patrol.
Kezngaz.
Operator error this time fortunately!!
Kezngaz.
