We have recently bought Atlantic caravan as shown in my avatar (Endeavour single axle off roadish)
We will be going on our first long trip in 2 weeks time straight up to Darwin from Adelaide, and then left all around the coast for about 3 months.
Now I know it's a new van, but I like checking things anyway. I was comparing the rim size of my tow car, as they both have 16 inch wheels, and I thought they may be interchangeable.
On looking at the rear of one of the van wheels, it has a a few stamps with specs on, and on one it says "maximum load 1250kg" for the rim.
My problem is that the van has an ATM of 2510kg. So does that mean that the rims are unsuitable, and 5kg each wheel under the legal limit???
That's how I see it, but I can't find any definitive explanation (had a MAN look) I am a little worried how an insurance company would react if they ever had reason to check...
The tire rating is ok at 1480kg each.
Should I be contacting the manufacturer?
I don't really need this just 2 weeks before we go, but I'd sooner sort it now than later!
Thanks for reading
Regards,
Brian
Peter_n_Margaret said
11:23 AM Jun 13, 2016
ATM includes the ball weight, so it is going to be technically legal.
Even if it is legal it is much too close.
Cheers, Peter
-- Edited by Peter_n_Margaret on Monday 13th of June 2016 11:25:39 AM
-- Edited by Peter_n_Margaret on Monday 13th of June 2016 11:28:20 AM
06:29 PM Jun 13, 2016
I notice many who travel on inland roads have what looks like aftermarket wheels with high / wide profile tyres . Makes for interchangeability iff stud patterns are the same ? Plus much smoother ride ..
06:45 PM Jun 13, 2016
Also of interest will be the actual weight of the rig on the road.
It would be a very good idea to weigh it when it is fully loaded and ready to go.
Also weigh each wheel of the van individually. It is not unusual for vans to be asymmetrically loaded (one side heavier than the other side). Kitchen side is usually the heaviest).
Do you know what the empty weight is?
dogbox said
08:01 PM Jun 13, 2016
try a wheel change an see if it fits an doesn't foul anything if it fits you could use the spare in an emergency till you can get repairs done
woofta and precious said
08:25 PM Jun 13, 2016
Thanks for the replies.
Yes, unfortunately the van rims wont fit on the car, just a bit out with the stud pattern.
The tare weight if the van is 2210kg, GTM is 2310kg and ball is 200kg
I did plan to hook the van up tomorrow to check the weight with most of the stuff in it, and full tanks of water and gas.
Going by the GTM then, I guess the rims are ok.... I may have to get my own rims for peace of mind!
I will follow up on this post.
Thanks again for the help.
Brian
Gus1949 said
04:20 PM Jun 14, 2016
The wheels wont be carrying 2510Kg because some of the weight will be on the tow ball and carried by the tow vehicle. You probably have around 200kg on the ball that could be deducted from the ATM. Further, you could probably deduct the weight of the wheels and tyres which is probably another 40kg. Still a good idea to weigh the loaded van including weighing both side separately that way you will have a better idea of how to load the van to get the best balance for towing.
08:00 AM Jun 16, 2016
No you can't, loading weights are based on the wheel weights being included in the total.
Hylife said
12:50 AM Jun 20, 2016
That is per wheel. Some of your weight is on the tow ball and not on the wheels.
The ATM is only a legal maximum. It is the most your caravan can weigh, with everything in and on it, as it stands, unhitched. It is the weight that each wheel and the jockey wheel impose on the ground all added together, at the very most.
Your van may not be at its ATM or if you have loaded up too much you may be over its ATM and be breaking the law.
The actual weight of the van on its axels only is called the Gross Trailer Mass GTM. This will be less than the ATM because some of your van weight is pressing down on the tow bar.
The weight pressing down on the towbar is called the Towball mass. The sum of the Towball mass and the GTM must not exceed the ATM.
If you do not have a tow ball weight scale, take the actual weight of the van on its axels by driving over a weighbridge and having just the van axels wheels on the weighbridge. Take the bridge reading and divide by the number of wheels and that is the weight per wheel. The weight per wheel must NOT exceed the wheel and tyre maximums
Different loading of the contents and the design of your van will alter the tow ball weight.
In your case the van might only have a mass of 2400kg being 110kg under the ATM. It might also have a towball mass of 250kg because of its design and how you have loaded it. This means your GTM pushing down on your axels is only 2150kg and for 2 wheels that is 1075kg per wheel which is under the 1250 maximum per rim.
Hi all,
Thanks for reading
Regards,
Brian
Brian
