We are looking at installing a diesel heater in our 5th wheeler. Looking for some feedback from people who have them installed. What brand do you have, good and bad points. If you have had any problems, what was customer service like to remedy situation. Anyone with bigger rigs, does a 2kw unit heat your area efficiently.
10:43 AM Jun 4, 2016
Firstly, Paul ...
There is a search function on the forum ... not the best search function mind you - but it often brings up past relevant posts.
If you put 'diesel heater' in the search box (above the posts in the blue banner line) you will get some previous posts on this topic.
Jumboqh said
11:12 AM Jun 4, 2016
Thanks John, I had already done that search. Most of the posts are a few years old. Technology changes quickly these days. I was after more current information.
Yuglamron said
11:29 AM Jun 4, 2016
This is one site. (Chinese) that sell Diesel Heaters. From what I can gather the copyright laws in China are different that ours.
Most of these seem to be a direct knock off of the Eberspacher design.
The latest ones have the ability to be switched on remotely with a smart phone. All nice and warm for your return.
The basic design is fairly simple ,cold air in exhaust out and hot air to interior and the exhaust should not be under an opening window.
Cost comparison seems to be about one quarter the cost of the genuine article.
There are others of a similar design called Planar which I understand a few "Forumites" have successfully self fitted. Snugger is another one which can also be mounted on a stand and used independently.
We bought ours from pinnacle no probs with it also good dealer have delt with them a lot over the yrs
dibs
ps wife loves it
aussie_paul said
12:39 PM Jun 4, 2016
We have not had our Plane diesel heater from Pinnacle Wholesalers 12 months yet but so far it works well in our 24' van, rarely have it above the lowest setting.
p.s. Pinnacle Wholesalers are wonderful to deal with.
-- Edited by aussie_paul on Saturday 4th of June 2016 12:40:17 PM
-- Edited by aussie_paul on Saturday 4th of June 2016 02:34:27 PM
Plain Truth said
02:36 PM Jun 4, 2016
Got ours from Diesal Heat, at
Tools & Associated Sales Pty.Ltd
166 Dixon Point Rd.
Sandford Tas.7020 Ph.03 6248 8720
Talk to Graeme Yost,very helpful,we wouldn't be without one now.
Kiwi-as said
08:11 PM Jun 4, 2016
Also got ours from Pinnacle, great heater, great dealer to deal with and easy to install, done it myself.
PeterInSa said
10:58 AM Jun 5, 2016
If I was purchasing/installing a Diesel heater again, I would seriously look at a Heater that has 2 output functions. a Unit that cycles ie heats the van up, then lets the van cool down a bit before heater starts up again and the second function that just runs the heater at a constant adjustable heat and fan operation.
I believe the Belief unit from Tassie does this but I have no experience/knowledge of this heater in use, or whether the constant heat/fan operation is more costly on diesel/battery.
-- Edited by PeterInSa on Sunday 5th of June 2016 10:58:56 AM
Delta18 said
11:05 AM Jun 5, 2016
This is the heater I put in our last van & the one that will be going in the new van. I am ordering it tomorrow.
Fuel consumption on the Power setting is minimal as it is turned right down once the room is warm enough.
Power consumption also is minimal as it is only running the fan on Low.
11:11 AM Jun 5, 2016
I'd say Pinnical are large enough to warrant and exchange also . I bought a 220 amp mig welder through them . A few parts where quite up to scratch . Without any problems they sent me new parts without worrying about returning the slightly defective parts ., Did me right only too happy to pass it on .
jab160 said
07:48 PM Jun 6, 2016
Fitted a "webasto" ...no problems at all.
JayDee said
08:19 PM Jun 8, 2016
166 Dixon Point Rd.
I to can recommend Greame. He was always there at the end of the phone when ever I had a problem or could not understand the instructions.
10 out 10 to this company for after sales service.
Jay&Dee
laurieoz said
08:48 AM Jun 9, 2016
Yes -I fully agree
mr glassies said
06:15 PM Jun 9, 2016
Just a word of warning if you or any one else for that mater install it don't put the exhaust and the inlet less than 1.500 from the gas tanks i have to extend both because there to close that goes for both gas and diesel .
Dibs
mr glassies said
06:22 PM Jun 9, 2016
That's did mr kewe
Jumboqh said
07:47 AM Jun 10, 2016
Thanks, where I have planned for the install should be more than that distance away. I assume you are talking metres.
mr glassies said
07:53 PM Jun 16, 2016
Hey kewe do your lights flicker when you start it . Tia where ya at m8 house sold went unconditional on Monday . We're moving to imbil next couple of days
dibs
meetoo said
06:31 PM Jun 17, 2016
HI Peter, the Planar heater I bought recently has both those 2 output functions, easy to control with the digital controller. I had to ask for the new instructions though, as the one that came with the heater was for the old controller. The 2 kw heater works well and I am glad I bought it.
Cheers John.
Delta18 said
06:42 PM Jun 17, 2016
dibs
Are you picking up the power for the heater from a fusebox? It really performs better with a dedicated power supply (fused of course) directly from the battery.
My instructions stressed this point. I ignored this when I first installed & got the flickering lights both starting up & also shutting down. Running a new power wire solved that.
Firstly, Paul ...
Lots to suss out. Hope you find what you want.
http://www.aliexpress.com/af/Diesel-Heater.html?ltype=wholesale&d=y&origin=n&isViewCP=y&shipCountry=au&shipCompanies=&SearchText=Diesel+Heater&exception=&minPrice=&maxPrice=&minQuantity=&maxQuantity=&isFreeShip=n&isFavorite=n&isRtl=n&isOnSale=n&isAtmOnline=n&CatId=200000406
Type in Diesel Heaters in their search field.
No affiliation with any the aforementioned heater companies.
-- Edited by Yuglamron on Saturday 4th of June 2016 11:30:02 AM
-- Edited by Yuglamron on Saturday 4th of June 2016 11:32:27 AM
dibs
ps wife loves it
166 Dixon Point Rd.
Jay&Dee
Yes -I fully agree
Dibs
That's did mr kewe
dibs
