I have a Motorhome and am putting 2 x 200watt solar panels on the roof, and have 3 x 100Ah batteries. I would like to put in a 2,000 or 3,000 watt inverter as I will will be doing a lot of free camping. I am have conflicting advise that the inverter will will draw too much power from the batteries. I want to use an appliance that is 1,800 watts occasionally, and perhaps a laptop from time to time. Could anyone advise me if I will get any problems ?
Colin
12:56 PM May 23, 2016
Welcome to the gang Colin, enjoy here and out in the playground.
Firstly, you are much better off puting your question in the "Techies" section of this great forum as there are many knowledgable people hang out there and your question will easily be found later once it gets in the dungeon area.
Secondly, I see no reason why your set up won't work, that said though, I would only use that 1,800w appliance during the day when the sun is doing it's thing with those panels and battery as yes it will chew into the batteries for sure. By using while the sun is doing it's thing the batteries are being topped up as they are being used. The other thing I would be doing is use the 3000w Inverter as 2000w is way to close for my way of thinking.
Keeping in mind Uncle Al gets up before me some days. I think he is still asleep as we speak.
Hope my thoughts on your question help.
Peter_n_Margaret said
01:48 PM May 23, 2016
Like "oils ain't oils Sol", inverters ain't inverters Colin.
It really depends if you buy cheap crap or quality.
I have a quality 1300W PSW inverter that is now 11 years old. It will run a 1500W load for 5 or 10 minutes and a 1300W load for ever.
In general terms, it will use about 10% more power than the large appliance when you are running it.
They also vary a lot in terms of how much power they consume when not running anything and an amp or 2 more than the appliance +10% when running small things.
Hylda&Jon said
02:45 PM May 23, 2016
My 2 cents worth If you want to use an inverter for a laptop you would need a pure sine wave one which is way more expensive. Also it is a lot of overkilll to use that size inverter for a laptop.
.....My 2 cents worth If you want to use an inverter for a laptop you would need a pure sine wave one which is way more expensive.
I agree you need a PSW (and that is safest for any use, especially for anything with electronics), but they are no longer much more expensive and it makes no sense to buy anything else.
Hylife said
06:00 PM May 23, 2016
Nope not so unless your laptop is really ancient like 15years + old.
As a veteran computer tech I can inform you that you can run just about any laptop from a cheapo $30 150Watt coke can inverter. For the last decade laptop chargers are multi voltage and accept anything from 100 to 260 volts AC and a modified sine wave or even square wave will do just fine.
The back of your charger will have the voltage and wattage ratings. The largest charger you can buy these days is 90watts at 220V AC.
06:33 PM May 23, 2016
Yep I use my laptop with the 12v adapter as mentioned but Colin also wants to use something that is 1800w. I noticed a comment at the bottom of a thread in Techies from back in November last year, it is a coffee machine. I'm prepared to be shot for butting in :)
-- Edited by Dougwe on Monday 23rd of May 2016 08:43:13 PM
lizard said
06:49 PM May 23, 2016
we have been using a cheap modified sine wave inverter for years for our laptops - no problems at all
Friar Park said
09:53 AM May 24, 2016
Colin I have a 2500 watt PSW inverter bought from "bit sales" 3 years ago It runs my electric kettle when needed. So long as you don't run it excessively it will do the job. just apply your common sense when using it.
Hi,
Colin
Best off using one of these: http://www.jaycar.com.au/IT-Products/Connectivity/Power-Products/150W-Car-Laptop-Power-Supply/p/MP3472 Instead of converting 12v into 240v then back down to the 16v or 19v that the computer needs, this device just converts 12v up to 16v/19v so is much less draw on your battery. All you need is a cigarette socket to plug it into.
Jon
Friar
