good morning everyone, when we switched on the water pump t did not work. Anyone else had this problem? Regards rocket n strop
graeme c said
08:08 AM May 19, 2016
Yep fuse on the Ctrek charger
the rocket said
08:44 AM May 19, 2016
hi graeme c , where can i find the ctrek charger? Thanks
hako said
10:34 AM May 19, 2016
First find if power is getting to the pump with one of those voltage testers that look like a screwdriver fro SuperCheap for about $10...if no power then work backwards along the cable to switch then fuse then battery.
Good Luck.
12:30 PM May 19, 2016
Is it just the pump ? Or has low voltage relay kicked in ?
Phil C said
07:11 PM May 27, 2016
Hi Rocket,
Is the pump running but no water, or is all quiet down there?
macka17 said
02:58 PM May 28, 2016
Actual pumps can calk it too.
I have one (dead) in shed.
Good Luck.
