I have just heard about these Solar Regulator/Battery Charger from the local auto electrician. Has anyone had any experience with them?
-- Edited by Symo2540 on Saturday 7th of May 2016 07:35:28 PM
Gaz n Shell said
09:44 PM May 13, 2016
G/day Symo
We,ve just put one in the cruiser,and are pretty happy with it,it was easy to fit and works well.
It is duel sensing ,which means it charges the starting battery first then switches over to the auxillary,it then switches back and forth when it sences a drop in voltage in either battery,pretty smart.
Gaz
Symo2540 said
12:11 PM May 14, 2016
Hi Gaz, have s Ctek Dual250 in the caravsn and works a treat was looking at this for yhe car second battery. Thanks for the feedback.
swamp said
07:45 PM May 14, 2016
HI
looking at the Enerdrive dc2dc around 1-2 mths ago
Around 450$ online
benefits
charging regimes can be tailered to exactly the type and voltages needed [very few are so adjustable ]
Good charge rate can charge to 30amps suitable for dual and single batteries
Can put 30amps into one agm batt if its specified to do so
10/20/30 amp optional
Lithium ready
Good support
[ Nb only very few are suitable for engine bay mount ,98% are not are not ]
I chose a cheaper 40 amp in the end mainly because of budget
Gaz
HI
Around 450$ online
benefits
Lithium ready
Good support
swamp
