Isuzu Dmax 2014 35000 kms Clearview towing mirrors Dual battery setup electric brakes Bull bar Uhf
After market extras 2 X 120w solar panels 2 x 100ah agm batteries 2nd tv in bedroom Eberspatcher diesel heater Includes Hayman Reece evolution hitch $4000
CAFÉ STANDARD FEATURES
METALLIC SILVER GEL COAT EXTERIOR ALUMINUM FRAMED, DARK TINTED SAFETY GLASS WINDOWS DIAMOND PLATED STEEL REAR BUMPER DOOR SIDE (REAR) PATIO AND SECURITY LIGHTS EXTRA CURB SIDE TV CABLE HOOK-UP EXTERIOR 240 VOLT POWER POINT E-Z LUBE HUBS 15 INCH ALUMINUM WHEELS EXTERIOR SPEAKERS REAR STABILIZER JACKS (2) ELECTRIC FRONT JACKS (2) RADIUS CORNER ENTRY DOORS, BAGGAGE DOORS AND WINDOWS PRIVACY GLASS ENTRY DOOR ACCENT COLORED ALUMINIUM SKIRTING ACCENT COLORED FENDER SKIRTING RAIN GUTTERS AND EXTENDED DOWN SPOUTS BREAK AWAY SWITCH LCD TV BRACKET / HOOK UP
INTERIOR ACCORDION STYLE DIVIDERS (WHERE APPLICABLE) SOLID WOOD MORTISED CABINET DOORS SCREWED AND GLUED CABINETRY ENHANCED COOL RUNNING 12 VOLT LED INTERIOR POT LIGHTING PACKAGE DÉCOR MIRROR RAISED PANEL WOOD OVERHEAD CABINET DOORS WALL MOUNTED INTERIOR LIGHT SWITCHES PADDED NO CRACK VINYL FLOORING THROUGHOUT
KITCHEN STAINLESS STEEL POWER EXHAUST RANGE HOOD WITH LIGHT KNIFE RACK PLYWOOD DRAWERS WITH BALL BEARING GUIDES CORIAN (MARBLE TYPE) COUNTER TOPS DOMETIC SS (AGA APPROVED) 3 cu ft, 120 litre 12V/LPG/240V REFRIGERATOR/FREEZER SMEV STAINLESS STEEL 3 BURNER COOK TOP WITH GLASS COVER (AUST MODEL AGA APPROVED) STAINLESS STEEL 240 VOLT MICROWAVE/CONVECTION OVEN & SURROUND STAINLESS STEEL SMEV MATCHING SINK WITH GLASS COVER
BATHROOM SKYLIGHT OVER SEPARATE SHOWER LARGE MEDICINE CABINET/MIRROR RECESSED OVER HEAD VANITY LIGHT TOOTHBRUSH HOLDER WATER SAVER HAND SPRAYER IN SHOWER POWER EXHAUST FAN TOWEL RAIL TOILET IN SEPARATE ROOM
BEDROOM QUEEN BED AND MATTRESS - 6' 6" L X 5' W (Please note our recent brochure's "features" section went to a new format and incorrectly included pillow top mattress. We regret an inconvenience.) BULLET READING LIGHTS ABOVE BED NIGHT STANDS DOUBLE 240V OUTLET AT EACH NIGHT STAND HANGING WARDROBE WITH TWO DRAWERS OVERHEAD STORAGE COORDINATING DESIGNER COMFORTER LIFT UP BED WITH GAS STRUTS AND STORAGE TV JACK AND LCD TV BRACKET LARGE STORAGE AREAS UNDER FOLD UP STEP TO BEDROOM
UTILITIES SATELLITE / CABLE HOOK-UPS WIRING TO ROOF FOR SATELLITE/SOLAR PANEL HOOK UP WATER PUMP/FILTER IN OWN COMPARTMENT ACCESSIBLE FROM EXTERIOR OUTSIDE SHOWER CO, LP, SMOKE DETECTORS FIRE EXTINGUISHERS (2) PROBELESS TANK MONITORS ONE-TOUCH SYSTEMS MONITOR PANEL 240 VOLT- 12 VOLT CONVERTER
ADDITIONAL CAFE CONSTRUCTION VACUUM BONDED WALLS, ROOF AND FLOOR ALUMINUM FRAMED WALLS, ROOF, AND FLOOR HIGH DENSITY, POLY STYRENE FOAM INSULATION IN WALLS, FLOORS, & ROOF SIX INCH HYBRID BOX SECTION/ I-BEAM CHASSIS WITH FULL OUTRIGGERS PROBELESS ROTO-CAST HOLDING TANKS
CAFE VALUE PACKAGE (INCLUDED) FULLY ENCLOSED UNDERBELLY FIVE SIDE ALUMINUM STRUCTURE AM/FM/CD/DVD (CODED FOR AUST/NZ ZONE 4) W/INTERIOR/EXTERIOR SPEAKERS 2 x 4.5 KG GAS BOTTLES WITH AUST MODEL AUTO GAS REGULATOR (GAS BOTTLES NOT SUPPLIED FOR NZ) 6 GALLON SUBURBAN (AUST MODEL AGA APPROVED) LPG/240 VOLT WATER HEATER W/DSI PORCELAIN TOILET W/ FOOT FLUSH PEDAL HIGH OUTPUT EXHAUST FAN IN BEDROOM OUTSIDE SHOWER TWO A&E POWER AWNING (ONE ON KERB SIDE AND ONE ON REAR) SLIDE TOPPER SPARE TYRE AND CARRIER MOUNTED UNDER REAR OF CHASSIS SWING OUT GRAB BAR PLEATED SHADES METALLIC BRONZE FIBREGLASS FRONT CAP WITH LED LIGHTS 13,500 BTU DOMETIC DUCTED 240 VOLT A/C WITH HEATING RADIAL TYRES TV ANTENNA (STANDARD POP-UP TV MECHANISM FITS UPTO 32" FLAT SCREEN TV)
CAFE SPECIFICATIONS DRY (KERB) WEIGHT APPROX 2100 KG (EXCLUDING AWNINGS, SPARE AND AIR COND) PAYLOAD APPROX 600 KG PIN WEIGHT APPROX 360 KG (DRY & LEVEL) 2800 KG ATM INTERNAL LENGTH APPROX 19 FOOT 6 INCHES 5944 mm EXTERNAL OVERALL LENGTH APPROX 22 FOOT 6705 mm EXTERNAL WIDTH 7' 4" , 2235 mm (OUTSIDE WALL TO OUTSIDE WALL) FULL HEIGHT SLIDE-OUT EXTERNAL HEIGHT EXCLUDING AIR COND 10' 1" (3050 mm) FRESH WATER CAP 140 L (inc HWS) GREY WATER CAPACITY 120 L BLACK WATER CAPACITY 120 L ALLOY WHEELS 15 INCH 2 x POWER AWNINGS (KERB SIDE AND REAR) 2 x 4 KG GAS BOTTLES
-- Edited by Glenelg on Thursday 5th of May 2016 01:34:51 PM
$80 000
Isuzu Dmax 2014
35000 kms
Dual battery setup
electric brakes
Bull bar
Uhf
After market extras
2nd tv in bedroom
E-Z LUBE HUBS
EXTERIOR SPEAKERS
BREAK AWAY SWITCH
MATCHING BAGGAGE DOORS
REESE REAR PIVOT EXTENDED PIN BOX
DEXTER 2700KG (6000LB) RUBBER RIDE AXLE, ELECTRIC BRAKE HUBS (WITH FULL AUST/NZ WARRANTY)
INTERIOR
DÉCOR MIRROR
KITCHEN
KNIFE RACK
BATHROOM
TOOTHBRUSH HOLDER
POWER EXHAUST FAN
TOWEL RAIL
BEDROOM
NIGHT STANDS
OVERHEAD STORAGE
UTILITIES
OUTSIDE SHOWER
OUTSIDE SHOWER
SLIDE TOPPER
SWING OUT GRAB BAR
PLEATED SHADES
RADIAL TYRES
CAFE SPECIFICATIONS
2800 KG ATM
Good luck with the sale Dave. Great price too.
Hi, Have you sold. If not would you consider separating. Chasing a Isuzu Dmax. And where are you located. Frankie sunny North Qld
