Hi we have two problems we cannot fix on the road the first is we are only generating about half the expected solar and suspect we need to run a separate line for the second panel we have a 40amp bcdc and it should be big enough for 2 200w panels. The other problem is that when we travel we blow the main 12v fuse we hxave tried isolating things but no luck any help with a recomendation would be appreciated
Trevor and Pamela
gemmybob said
11:19 PM May 1, 2016
There's a Solar sub forum in the Techies forum, you might find some answers there, its worth a look.
Good luck
Cheers gemmybob
The Doo crew said
08:08 AM May 2, 2016
Where are you in Darwin?? Im out at Humpty Doo & might be able to help.
Pamela G said
10:53 AM May 2, 2016
currently at Adelaide river and plan to spend some time in Litchfield then on to Darwin I will pm you if thats ok
Good luck
Cheers gemmybob
Sounds like a plan.
