Has anyone found an easy way to insulate the inside of the four season hatch when it is not being used. I am considering a cut to measure piece of foam along with an appropriate sized window shade to help hold it in place. I am surprised that it was not manufactured with a removable "shelf" that could be placed inside the "lip" area of the hatch when not being used?
Just thought I would ask if anyone has found anything suitable or have a better ideas?
villatranquilla said
05:22 PM Apr 29, 2016
we glued a piece of styrene to the inside of the hatch but have also cut some larger corflute which then sits on 2 spring loaded curtain rails within the hatch so it sits just above ceiling height - styrene is permanent while the corflute is easily removed to allow for ventilation
-- Edited by villatranquilla on Friday 29th of April 2016 05:23:36 PM
cjt55 said
06:47 AM Apr 30, 2016
Thanks for the reply Jenny and Barry. Your idea is he sort of thing I am looking for. Two heads are better than one.
Col
09:45 PM Apr 30, 2016
Warning, all vans are required to have permanent ventilation. The bottom vent is usually in the bottom of the entry door. The top vent is required to be remote from the bottom vent.
Does your van have a permanent ventilator on the wall opposite the door and sown the opposite end. Most vans with Four Seasons hatches do not, the top vent is in the hatch. See this link. you will see the following under the heading "Features."
161 square cm of fixed ventilation, even when closed.
Complies with gas code
If your van does not have the necessary wall vent then do not block the ventilation in the Four Seasons hatch, it is necessary for the gas regulations.
Radar said
11:01 PM Apr 30, 2016
-- Edited by Radar on Sunday 1st of May 2016 07:11:24 AM
Col
