If you are down Esperance way, keep this in mind. A firm that does electricrical work on motor vehicle did some "work" on my Madza T 3500 M/home. As a result, the headlights come on at any time, Vacuum light stays on. Glove box won't open. One radio speaker isn't working anymore. No power to cigarette lighter. High beam indicator light doesn't work anymore. Low water buzzer and light won't turn off. (Radiator and o/flow are correct level.) When quizzed about these problems, the answer was, "Dunno what's wrong"
Cheers.
Pipes
03_Troopy said
06:14 PM Apr 29, 2016
And what was their reply when you brought the matter up with them?
iana said
09:45 AM Apr 30, 2016
Yes, but did you get the problem they worked on fixed ?
Dhutime said
04:28 PM Apr 30, 2016
Interested if and how this this fixed as our head lights won't turn off at the moment and no auto electrician is working here today .
Dhutime
pipes said
06:33 PM May 1, 2016
I gave up on getting any more done. Got to Kalgoorlie and the vacuum pump on the back of the alternator has stopped working.
End result, recond. alternator and vac, pump.
About $1,000.oo. I won't complain, seeing as this is still the best, and safest country in the world.
Regards.
Pipes.
G'day.
Cheers.
Pipes
Dhutime
Regards.
Pipes.
