hi I'm looking for some tyres for our Toyota coaster. The ones on it are hankook 6.50R16 LT. when I look online or ring tyres places I have no luck. Most I see have a 195 or 205 etc in front of the 6.50 R16..... Tyre conversion guides don't help much either.
can anybody please help me find out the correct number I should be looking for?
Ive measured the "width or thickness" across the top and it's about 150 cm..
Hi Caliban, try the site tire size.com I think you may be able to source what you are looking for there.The size you quote is obviously an old imperial size.The 6 represents 6 inches 50 is the percentage of profile followed by the rim size in inches.It looks like later model coasters have wider rims. Perhaps there is a coaster forum or group you could contact for information exchange.
Baz421 said
08:33 PM Feb 14, 2016
6.5 X 16 diameter (not low profile LT tyres)
see this link, not sure how good they are but they are available
-- Edited by Baz421 on Sunday 14th of February 2016 08:37:28 PM
Peter_n_Margaret said
05:44 PM Feb 15, 2016
That is not correct.
6.50 R 16 means the tyre is 6 1/2"wide. It is a radial tyre with a 100% profile and fits a 16"rim. This is an imperial size.
It is likely that a 7.00R16 may be OK and there are likely to be metric sizes that will suit as well.
Try Michelin.
exa41 said
11:32 PM Feb 15, 2016
I took the 6.50 s of and fitted 7.00 they are available anywhere just enquire. got mine for $175 each in Melbourne ,cant see any reason you cant get them elsewhere.
www.tyresales.com.au/tyres/hankook
I don't know where you are but this place is in Brisbane
www.bosmantyres.com.au/
Ebay has also produced some results
http://www.etyrestore.com.au/online_store.php
several more here - with specs in pdf format
http://toyotires.com.au/tyres/light-commercial-tyres
Try Michelin.
