Hi all my wife and I are travelling from Kiama to Cooma next week ... Wondering if there are any issue on the Braidwood Road, Just need to know that my 96 Ford and 18 1/2' van will travel ok on it??? Any assistance would be appreciated. Tom and Chrissy
Long Weekend said
03:08 PM Feb 12, 2016
Hi Tom and Chrissy,
No doubt you are worried about the Clyde Mountain. Apart from being a pretty hard slog in low gear it isn't that bad going up. The road surface is good and wide with regular overtaking lanes. The actual climb is about 5kms; at the bottom check your odometer and count off the kilometres otherwise it seems to take forever.
We towed our 17ft van with our BF Falcon up the Clyde the last time in November, mostly in 2nd.
Once at the top the road is winding with double lines for what seems to be about ten kilometres - it can be frustrating when behind a slow vehicle. Then for the last 10kms or so to Braidwood it is a normal country road. From Braidwood to Bungendore the road is generally good with some bends and undulations - watch out for idiots overtaking no matter what.
In February 2010 we went to the Easts Caravan Park in Kiama - on the way went down Macquarie Pass - which is a lot worse than Clyde - but returned via Mount Ousley. It was 300kms to Canberra via Mt Ousley (why it was exactly 300 I don't know but that was the odometer readings) versus 238kms down Macquarie. But it was faster!
If you have any worries you might like to go up Mt Ousley, across to join the Hume, take the Federal Highway south of Goulburn. Then just as you cross the border into the ACT take the exit onto the Monaro Highway. Not sure what the exit markings are these days but the exit ramp drops down past a rest area. Turn left. That road goes all the way down to Cooma. About 10kms along there are bridge works where the highway crosses the Molongo River and traffic is diverted to two way.
Another way to go is via Nerriga. Go past the Navy base HMAS Albatross at Nowra, then a kilometre or so past Nerriga take the Tarago turn off to the right. That joins the Bungendore/Goulbourn road just north of Bungendore. I have driven the Braidwood to Nowra road several times but not the Nerriga to Tarago - but a friend has told me that it is OK. The Braidwood - Nerriga road has some gravel - one 5km stretch, then a 13km length giving a total of 18kms of gravel.
BUT; the Nerriga way is a pretty gentle climb and the road generally straight. In fact, when the Clyde was closed for a month due to a rock slide all Batemans Bay traffic was detoured through Nerriga.
To finish up Welcome to the playground.
Murray
08:22 PM Feb 12, 2016
Welcome to the gang Eshy, enjoy here and out in the playground.
Now, I know people in Batemans Bay that think the "Clyde" is a small hill, Me, well, it's a bloody big mountain and I tell you that for free. Hope that is of some idea for you.
Keep Safe on the roads.
Long Weekend said
08:49 PM Feb 12, 2016
Well, yes. As Dougwe says it is quite a high mountain. A continous five kilometres of heavy low gear work around tight turns even without towing a van. By the way, there is about 10kms of up and down tight turns even before you get to the start of the climb.
But it is better than Macquarie Pass on the Illawarra Highway. (One particular corner requires you to back up then go forward to get around.)
After being on all roads - Macquarie Pass, Mt Ousley, the Clyde and even Brown Mountain I would recommend going north from Kiama and up Mt Ousley, then onto the Hume. On the map it is a lot longer but the roads are almost all freeway so they are faster. Mt Ousley, while steep, is six lanes wide and mostly straight with a speed limit of 80km/h.
Murray
JohnR said
10:05 PM Feb 12, 2016
Spent some time at Kiama in my banking days. We would pull up to Wollongong (Mount Ousley) and go the long way down the Picton Road on to the Hume/Canberra. Would stay away from both the Clyde and the Brown understanding the steepness of both and what tug you are utilizing.
Another option is South Nowra, Sassafras, Nerriga, Oallen, Windellama then to Goulburn. I know the road is sealed and the Navy/Airforce buses come this way when going from Albatross to Canberra.
JohnR
Dav4Cris said
10:06 PM Feb 12, 2016
We always use the Main road 92 road from Nowra to Braidwood, but we turn right about 3 klms out the Braidwood side of Nerriga sign says Goulburn and follow the road out through Ollaen Ford and Windellarma and onto Goulburn, you come out near the airport and from there you can go into Goulburn or across to South Goulburn near the big Merino, where you can get on the Hume, no dirt, a bit windy but no really steep climbs like the Clyde or Browns Mountain. We tow a 21' Jayco with a 2009 Holden Colorado no problems.
11:49 PM Feb 12, 2016
The road from Nowra through Nerriga (Main Road 92) is in top condition up to a little way through Nerriga. It then deteriorates to a gravel road with the gravel in large sizes. As far as the direct road from Braidwood to Cooma I am not sure of this.
My route would be to go just past Nerriga and turn towards Goulburn through Oalen Ford (now a bridge) to Tarago. Go through Tarago to Queanbeyan and join the Monaro Highway on the other side of Queanbeyan. You will have bitumen all the way with that route.
Dav4Cris said
06:54 AM Feb 13, 2016
Yep PeterD that would be the best way, forgot they where going to Cooma. Yes and a lot better climb than any other way.
-- Edited by Dav4Cris on Saturday 13th of February 2016 06:55:44 AM
Murray
Murray
JohnR
