Hi , I have a hayman reese wdh with the heavy bars (800lbs) 30", but the ball weight of my van is 260kg. Should I change to the lighter bars.
Thanks Owen.
Explorer said
06:32 PM Feb 4, 2016
Thanks Owen.
No. Guessing the van weight is around 3tonne, You are better off with the heavier bars & "load" them up to suit.
Mike.
KevinC said
08:13 PM Feb 4, 2016
I agree. There's enough adjustment available to set the WDH up correctly.
Baz421 said
08:16 PM Feb 4, 2016
I agree with Explorer and Kevin C.
You have the best option ie you ease off the pressure.
Many find they could use more heavier bars.
OwenK said
02:55 PM Feb 5, 2016
Thank you all for your opinions. I reckon you're right.
Cheers Owen.
06:13 PM Feb 5, 2016
A lot depends upon the loaded weight of your van. If you reveal that you may get a better response. For starters what are the tare weight and ATM of your van?
HR guides indicate that the 800 lb kit is for ball weights over 275 kg ball weights. The stronger bars are going to apply more stress to your drawbar than the lighter ones. I would be more concerned about that.
OwenK said
08:24 PM Feb 6, 2016
Thanks Peter, I know what you mean, that's why I put the question forward. Perhaps I should take the whole rig to Hayman-reese and have them check it out.
Thanks Owen.
Mike.
Cheers Owen.
Thanks Peter.
Ball Weight (kg) Appropriate system
0 - 80 kgs Mini
80 - 135 kgs Intermediate
135 - 275 kgs 600lb Kit
275 - 365 kgs 800lb Kit
365 - 545 kgs 1200lb Kit
The above table is from Hayman Reece Web sight. http://www.haymanreese.com.au/products/weight-distribution-systems
Regards John K
-- Edited by John Kay on Wednesday 10th of February 2016 08:04:52 PM
