Thanks but what I looking for old TV are LED the new one's are OLED or 4K and I was hoping that someone know which is better OLED or 4K , Thanks anyway .
10:00 PM Jan 30, 2016
Sheesh they are cheap! Aha
valiant81 said
09:40 AM Jan 31, 2016
Hi all;
As for oled / 4k televisions. The only manufacture at the moment is LG and about 55" is the smallest screen size, so way to big for a caravan ( unless you have a very BIG caravan ) . Cost would also be a big factor.
If I was you i would have a good look at the Kogan brand, cost wise and for back up if you have a problem. 12 Volt as well. While i don't have a kogan other members seem to find them ok.
Good luck with your search !!
10:41 AM Jan 31, 2016
We purchased a Kogan 24 inch with USB , 12v or 240v - $172 delivered -great picture and a lot bigger than our old 19", which fell out the cupboard. and rattled!
We bought a Kogan with a DVD player in it. Cost around $170. Been working fine for the past 4 years. We weren't after surround sound or anything, who needs that in a caravan? Very happy with ours, picture's as good as anything getting around.
03_Troopy said
11:10 AM Jan 31, 2016
About the best of a bad bunch I have found is Palsonic. they have a 21.5" and a 23.5" for around $300, that will run off 12V You won't find too many top brands that make 12V TVs unfortunately.
Not cheap but we use this as it is compact with USB for recording and Vast Satellite receiver integral with the TV. We can use it anywhere With the Sat Dish or the Standard Antenna.
brickies said
11:46 AM Jan 31, 2016
Was not looking for a cheap tv , I am looking for the best TV ,And have been told it's between OLED and 4 K TV picture and just thought someone may know which is the best . Thank for your fed back
Hylife said
12:28 PM Jan 31, 2016
Currently TVs are available in four resolutions.
Standard, Hi Definition, Full High Definition, Ultra Hi Definition.
Almost no-one is broadcasting anything other than standard definition with the occasional Hi Definition movie. Having a 4K (ultra) TV will not make any difference to your broadcast reception and viewing quality.
There is no broadcasting of any Full Hi Def or Ultra Hi Def in Australia as the transmission bandwidth is not available with current technologies. Full and Ultra are for connecting up BlueRay players.
Think of buying a car capable of 300kph but the only place you can drive it is in local 60kph streets. Bit of a waste of money.
The O in OLED is for Organic. Manufacturers are pushing the 'Cleaner for the environment' by using 'Organic' materials cr@p. There is no difference in quality of manufacture, veiwing or cost.
The benefits of LED over LCD in general is:- sharper (smaller dot pitch), brighter (good for higher ambient light environments, eg outside), faster response (less blur in fast moving images), far lower power consumption.
Cruising Cruze said
12:31 PM Jan 31, 2016
Hi Brickies
Not really small sizes are there yet in 4k
What I've seen is 40 inch as the smallest size
maybe an LG 27MU67 27in monitor with a 4k setup box???
Cheers John
brickies said
12:44 PM Jan 31, 2016
Thanks Hylife and John sort of information I was looking for
"Organic" TV's hey! Next we will see "Halal" certified Tv's
I know, off to the naughty room....sorry, couldn't resist. Spose it was still "on topic" though
Hylife, your comments make sense though, thanks for that info.
brickies said
01:52 PM Jan 31, 2016
Thanks John I had found that site 3 days ago it is a good one , But has Hylife the TV station don't broadcast to any standard like that , But we buy a lot of dvd which are to a higher standard and we don't know what's around the corner .
03_Troopy said
03:52 PM Jan 31, 2016
Just one small point on the difference between LED TVs and LCD TVs. The LCD TVs have a Liquid Crystal Display which is backlit by flourescent tubes, where a LED TV has a Liquid Crystal Display backlit by LEDs. So LED TVs are less power hungry.
Cloak said
08:05 PM Jan 31, 2016
I like Dougwes reply... And am off to the naughty corner too for what I want to say.
Back on topic I think go for both OLED and UHD. We use UHD here at home base for streamed movies and you really can see the difference.
The set we have will upscale SD and HD too so look out for this feature.
We're setting up a library for on the road - burning all our box sets onto a USB drive.
Need a new caravan too - what is CELL like?
Cruising Cruze said
02:43 PM Feb 1, 2016
Hi Terry
That's only a question of time before we see 4K on tv
In 8 or 10 years from now that 4K will be obsolete
By that time we have even better systems
Regards John
brickies said
02:55 PM Feb 1, 2016
True
valiant81 said
08:53 PM Feb 2, 2016
Hi Brickies;
When you are talking about a new television, are we talking for the caravan ???? OR are we talking about for the main television in the house ( lounge room ). Both have there own set of requirements, size, 12 Volt, HDMI or component input, even the old composite video input all play a important part in what you require and what equipment you want to interconnect to your set.
Baz421 said
08:57 PM Feb 2, 2016
Cruising Cruze wrote:
Hi Terry
Regards John
Yes and our eyes will compensate,,, so in effect the definition should stay the same as we age,,,lol.
Cruising Cruze said
09:04 PM Feb 2, 2016
@ Barry ( Baz )
brickies said
05:42 PM Feb 4, 2016
Thank it is for home ,I have 29" Panasonic led 12volt / 240 in the caravan with all the bells and whistles like built in DVD player and USB
Hi looking to buy a new TV , There are some new types out, Led , Oled and 4K does anyone know which type is the best .
After previously purchasing earlier TV's I can't say there's much better ?
Especially DVD USB for hard drive connection ..
Hi all;
TV 22" 12v/240v VAST Altech UEC integrated LED/LCD HD AL-22TVCM421PVR
Cheers John
Here is some more info
http://lcdtvbuyingguide.com/4k-tv-reviews/oled-vs-4k.html
Cheers John
Hi Terry
Regards John
Hi Brickies;
@ Barry ( Baz )
