We've got a Windsor caravan and having a problem with a water leak coming in through the window winder, and we've replaced the winder 4 times now and it's still leaking. Rivets, Arm and between the winder and window frame have all been sealed.
Any suggestions on where the water might be coming in?
Little Possum
Cupie said
11:41 AM Jan 22, 2016
When I first got my van I had some minor leaks in a few of the windows. I put a dob of silicon on the top off all the rivets on the winder mechanisms and that fixed it.
The front window sometimes had water blowing up thru the bottom rubber seal (in strong wind). I just twisted the frame a bit & applied a smear of vaseline from time to time. Fixed that too.
Brenda and Alan said
12:18 PM Jan 22, 2016
Could you clarify if it a front side window or the window across the front of the van please. However a leak between the caravan skin and frame of window around the top can find its way in via the winder.
Alan
little possum said
03:35 PM Jan 22, 2016
Thanks Alan,
It is the front window that's leaking and is coming through the winder.
Dave
little possum said
03:37 PM Jan 22, 2016
Thanks Guru Cupie,
We've done all that and still no closer to finding the leak as it's dripping from the bottom of the window winder.
Dave
TAJ said
07:43 PM Jan 22, 2016
HI had water coming in front window the situation we were in the only
thing i had was silastic and put it all around the window and locked it
never to be opened again they are similiar to front boots some not waterproof
Hello everyone,
Little Possum
Alan
Thanks Alan,
Dave
Thanks Guru Cupie,
Dave
hope it helps
