I usually leave my gas bottle turned on when travelling so that when I stop en-route, my fridge automatically changes from 12v to gas and starts up without my having to access gas bottle and turn on. Does anyone see a problem here
elliemike said
02:43 PM Jan 12, 2016
What happens if you pull into a Service Station. Does your Fridge fire up on Gas !
If so I would think you are disobeying the NO NAKED FLAMES signage.
Delta18 said
03:14 PM Jan 12, 2016
I'm pretty sure there is a time delay built into these fridges which give ample time to stop & refuel and leave before the gas ignites.
Anyway, if a fuel stop is planned on the next leg of a trip it wouldn't be hard to turn off the gas prior to leaving.
Cheers Neil
eric2011 said
03:58 PM Jan 12, 2016
If I am going to fuel up (i'm diesel) but I switch off the gas as I am aware of the reg's
eric2011 said
03:59 PM Jan 12, 2016
Cheers Neil
I'm pretty sure my battery supplies power for 15mis (I think) before it automatically fires up the gas
eric2011 said
04:00 PM Jan 12, 2016
My main reason for the question was to make sure of any safety issues for me. i.e. the gas turned on while travelling
When switching from one energy source to another, there are some delays implemented in the AES system. The 15 min. delay between switching off the engine and starting gas mode is intended to delay the starting of gas mode e.g. when stopping at a filling station.
Possum3 said
01:47 AM Jan 13, 2016
Eric the fact that you are utilising only diesel bowser doesn't effect the fact that other service station customers may be using petrol and regardless dangerous fumes are ALWAYS present at service stations.
In NSW the Storage and handling of dangerous goods is governed by WorkCover www.psych.usyd.edu.au/whs/HAZMAT/storage-handling-dangerous-goods-1354.pdf Sect 10.3.3 states that valve must be securely closed when not in use unless connected by permanent piping. Ipso Facto you may be prosecuted under this section for failure to securely close valve when travelling.
Regardless of legalities it would be extremely unwise to travel with open gas lines as in the case of a vehicle collision the line could be ruptured with a resultant explosion significantly probable.
teago said
09:11 AM Jan 14, 2016
I think that what you are doing is a very dangerous action .
teago
dazz49 said
09:27 AM Jan 14, 2016
Switch the gas off when travelling. A gas leak in the van could be catastrophic, and not just when you pull up for fuel. Why take the risk.???
oldtrack123 said
06:49 PM Jan 15, 2016
DITTO
Bruce and Bev said
11:32 PM Jan 21, 2016
I was told by our 'vans selling Dealer service staff that it is illegal to drive with your gas bottles turned on. Don't know if its correct or not but I don't feel safe with them turned on.
Unless youre stopping for a few hours and open and close your fridge/freezer doors for any length of time, then your fridge shouldn't drop temp for a 30 minute tea and comfort stop :)
Cheers Neil
From page 5 of this document:
teago
DITTO
