hello i,m thinking of fitting a friction sway control to my Pathfinder that tows a two axle Windsor Genesis caravan, what do fellow nomads think of this device ?
07:17 PM Nov 23, 2015
What is the ball weight of your van? HR recommend friction sway control for vans with ball weights up to 200 kg. For vans with ball weights over that they recommend their Dual Cam High-Performance Sway Control
Brooksy48 said
08:55 AM Nov 24, 2015
i have a HR anti sway bar attached to my pathfinder and dual axle Jayco. I does appear to make the van more stable, especially when buffeted by wind from oncoming semis.
Gus1949 said
02:33 PM Nov 27, 2015
I think the Alco Electronic Stability Control system is far better as it works using the vans brakes to control sway when you get severe sway, I doubt friction control would be very effective in those situations and that's when you really need assistance. A well balance reasonably modern van shouldn't cause any tracking problems if towed sensibly.
