Question for the knowledgable, can I fit under the bonnet a deep cycle battery with the crank battery both charging off the altenator through my Redarc battery isolater? I have a lead acid there wich is pooped at the moment does it matter having a deep cycle charging off the altenator? Thanks in advance.
Lance C
Peter_n_Margaret said
10:33 AM Nov 7, 2015
No problem, except some advise that AGMs don't like the under bonnet heat, others suggest it is OK. It may vary by brand.
I have no personal experience in that.
12:44 PM Nov 7, 2015
Heat shielding and possibly some vent for air ? Some have this as std...
I run a pice of alloy plate between engine and battery with 1/2 spacer ..
Air gap allowed air between battery and shield when driving ..
This was in Triton 4wd work vehicle . Where slow in national park driving which creates
Plenty of under bonnet heat.. Didn't need to top up water in battery half as much...
Yuglamron said
12:47 PM Nov 7, 2015
This is a general site re twin battery set ups. I don't know if you will find your answer but it is a general info site.
Lance C
http://www.fridge-and-solar.net/dual_bat.htm
-- Edited by Yuglamron on Saturday 7th of November 2015 12:56:36 PM
