Hi all, Fitting Hot water shower unit to outside of van
Michelle said
07:34 PM Oct 13, 2015
I was wondering if any of you have fitted a hot water shower unit to the outside of your van, we are going around the country next year in our pop top, this doesn't have a shower inside but have looked on line and you can buy units for $300.00 ish fitted outside you only have to have a portable pop up cover to stand in. As anyone seen or have one of these.
03_Troopy said
08:59 PM Oct 13, 2015
Hi Michelle, check out myswag.org These units have been mentioned a few times.
Wombat 280 said
09:13 PM Oct 13, 2015
Mate their are heaps of configurations available on the net If you get a mains pressure unit make sure it comes with a suitable 12 volt pump with filter for dry water . If you are using 240 power and mains pressure water supply then Bunnings have a unit for around $200 - 300
Cruising Cruze said
09:22 PM Oct 13, 2015
Hi Michelle
First of all welcome to this website
Have a look here,It was on a mate's caravan before he got his new one (caravan that is )
Thanks everyone. I've looked on the net they look great,
Sarge9 said
10:12 PM Oct 13, 2015
been tossing coins in the air myself.... was wondering about the GSWH-1m (Guirrand??) from AwardRV / Australian RV that I saw this weekend at the Melb CV show. but I then found these two on Fleabay..
the idea of saving $300 and not knocking holes in the van are appealing....with same outcome. Just dont know about the quality of the units. the GSWH has got a few ticks on here and are apparently a big deal in the Untied States..
Keep us informed
Sarge.
Wombat 280 said
12:55 PM Oct 14, 2015
Found this add while in the room with a view, may be of help talking with the manufacturer
Just a word of caution, if the hws units you are considering are gas fueled then make sure they are approved for use in Australia and the connection to your gas supply if hard connected has to be done by a licensed gas-fitter with a Certificate of Compliance issued to the end user. Happy hunting, Red72.
Hi Michelle
http://thegreynomads.activeboard.com/t35973928/hot-water-on-tap/
is this where you looking for??
Cheers John
-- Edited by Cruising Cruze on Tuesday 13th of October 2015 09:24:25 PM
Keep us informed
Sarge.
Thanks, yes I've been looking on eBay as well, look great
I'm just about to buy one of those Hot Tap units by Joolca, a mate has one and they work awesome and really easy to use as well..
-- Edited by Jamie and Kerryn on Friday 16th of October 2015 10:28:31 AM
-- Edited by Jamie and Kerryn on Friday 16th of October 2015 10:30:06 AM
