hi MEN and LADY;s stuck on a problem ? can anyone tell me how to remove sliding side windows and frame in one piece along sides ? thanks john
dragonfly1 said
01:00 PM Sep 24, 2015
If you mr Google he will tell you remove the clips under the inside trims and then cut the silastic
Dragonfly1
Sharke said
03:41 PM Sep 24, 2015
which year or model is the coaster.
Jeff
The Doo crew said
06:42 PM Sep 24, 2015
Both of mine we just pulled off the "pinch weld" plastic trim then removed the little metal clips. The black mastic will come apart with a little pressure.
Make sure somebody is ready to catch it on the outside as the glass sliders will fall out as the frame distorts.
$300.00 costly lesson my first removal was. Had to take them out to remove the white plastic stops & screws that restrict the windows opening.
Dragonfly1
Jeff
