Has Anyone had any experiences good or bad of a Diesel/LPG dual flue motor?
Is there running and maintenance savings to be had?
blaze said
10:57 AM Sep 14, 2015
yes, its good. It gives a more complete burn of the diesel, means less carbon particals in the oil. About half a gear power gain
blaze
02:28 PM Sep 14, 2015
Welcome to the gang sirbasil, enjoy here and out in the playground.
Your question has been answered and sure others will follow with more info for you.
02:30 PM Sep 14, 2015
Edit.....ooops, double up for some reason, sorry.
-- Edited by Dougwe on Monday 14th of September 2015 02:33:27 PM
Hallmark1 said
05:51 PM Sep 14, 2015
Hi sirbasil,I had a Patrol fitted with diesel/gas(4cyl) and it had really good extra power.The engine oil stayed a lot cleaner as well.The patrol had done 290000 ks when I upgraded with not a problem.I don't know whether I would do the same with a later model vehicle.
Hope this helps.
Cheers Baz
Woody n Sue said
09:04 PM Sep 14, 2015
Welcome sirbasil from us two 2 have only heard good things but have not any personal experience
Baz421 said
09:35 PM Sep 14, 2015
I would do conversion but the cost was a disincentive as was the space/weight for gas storage, just our decision. May review if we change the back of the truck to soft top traytop and going around 70% of coastline.
Gus1949 said
02:23 PM Sep 15, 2015
Have heard there is little benefit with modern diesel engines, suggest you ask a diesel expert like Berrima Diesel in Berrima.
blaze said
03:15 PM Sep 15, 2015
mine was on a modern high tech diesel
see my earlier comment
blaze
Baz421 said
09:09 PM Sep 19, 2015
Yep they say it is beneficial,,, especially the $ saved after conversion.
sirbasil said
05:40 AM Sep 20, 2015
Thanks to everybody for their replies, I can now take it that the consensuses of opinion is that it will not be a waste of money and time:)
Roadstogo said
08:34 PM Sep 28, 2015
Hi sir basil I ha . a 4.2 turbo diesel with gas fitted.got it Donne about 9years ago and has not missed a beat.got car dynod and showed a 18 kwt improvement.i would certainly recommend it .mind u the price of gas was a lot lower then as well cheers shayne
blaze
Hope this helps.
Cheers Baz
blaze
