While we are new to this forum I have a lot of experience, I am now retired but spent my life building boats, I am happy to help answer questions on systems if any one needs help, our motor home can be seen at http://spiritfreedom.wix.com/spirit-of-freedom your email can be left at the web site should you want infomation.
The vehicle is a 1981 Hino BX341 the fit out was done with Qld red cedar, polished in satin finish, the walls are box structure bulkheads, doors and draws are light weight build in the same principles as boats to save weight.
The electrical systems are shore power, generator 4 kva, house bank, 24 volt system, 4 x 12 volt 250 amp AGM, 1 x1800 watt 1x 6000 watt inverters, 6 x 24 volt solar charging panels.
LG dishwasher, LG front load washing machine, twin split system AC unit plus Dometic B3000 roof AC unit. Dometic three way fridge freezer, Lofra 600 mm gas burner oven.
We have lived in the motor home for over 3 years we rent out a couple of houses for income and stay on properties where I help the owners get on top of jobs.
Any way that's enough from me, enjoy life or change what your doing.
aussietraveller said
12:35 AM Sep 10, 2015
Welcome to the forum Shayne I am sure you will have many opportunities to assist other members there is a section for asking technical questions and it may be worth keeping an eye on this section of the forum
grahos said
08:59 PM Sep 13, 2015
Welcome Shayne to the forum,Hope to see you on the road one day.
