G'day everyone,
We are the proud new owners of one of these gorgeous motorhomes. Does anyone know the genuine height from rooftop to ground please? I do suspect we won't be using an underground car park
Thanks in advance for your help.
Glenelg said
07:51 AM Aug 30, 2015
Looks good well done. I have no idea of how high it is. What I done was go out with me tape, differant makes differant sizes I need 3.4 clearance on my 5th wheeler. Lots of low roofs on servos more so the older one
banjo said
11:57 AM Aug 30, 2015
Without sounding facetious, wouldn't a tape measure be easier and more accurate to find the size of your rig ?
I measured mine on day one, nearly 4 years ago, simple 3.2m clearance, no guesses or false info from some other similar rig that may or may not be different anyway.
rayjanet said
04:51 PM Aug 30, 2015
Thank you Glenelg and banjo, I did use a tape measure so discovered anything over 3.8m will be fine. Mind you, I leaped out of the truck and double-checked at the servo. I believe this is one of the last Bradstreets to be made, the dealer was hazy and I have lots of questions about how things work. My husband will have to do a lot of hunting and testing, lol.
dishlicker said
07:42 AM Aug 31, 2015
Hi the best way is to use a step ladder and tape you need to add the air con on top so on a step ladder run the tape from top to grond and eye in the top of the air con and add 100mm for safety you will get a more precise measurement this way good travels
